Greddy is back with their new "Multi D/A Gauges"
Greddy has come out with a single gauge that does everything!
Everything the popular brands do plus a LOT MORE! Here are a couple highlights!
· Hybrid analog dial with integrated digital display.
· Monitor up to 3 different readings on just one easy to view unit.
· The Multi D/A Gauge uses the latest generation electroluminescent display.
· Ideal size and style for visibility.
· Available in two main Analog types: Oil Pressure and Turbo Boost
· Specs: 62mm Diameter, 45mm depth
Includes: Wireless Remote Control, Sensor Center Unit, Main & Power Harness, Boost Sensor or Oil Pressure sensor, Sensor Harness, and Gauge Holder
Set adds: 1x (Water/Oil) Temperature Sensor & Sensor-Harness, 1x (Oil/Fuel) Pressure Sensor & Sensor-Harness.
*OPTIONAL SENSORS SETS AVAILABLE:
(Oil Pressure, Fuel Pressure, Water Tempature, Oil Tempature, EGT)
- For easy sensor installation also see our:
Water Temp Adapters, Tapped-Oil Drain Bolts and Oil Block Adapters.
Multi D/A Gauge Set Boost,Temp,Press 62mm Dia. Turbo (Boost) Dial 16001710
Multi D/A Gauge Set Press,Temp,Temp 62mm Dia. Oil Pressure Dial 16001711
Multi D/A Gauge Boost 62mm Dia. Turbo (Boost) Dial 16001700
Multi D/A Gauge Press 62mm Dia. Oil Pressure Dial 16001701
Boost Sensor Set Multi D/A 4mm Dia Opt. Boost Press Set 16401920
Pressure Sensor Set Multi D/A 1/8PT Optional Oil or Fuel Press Set 16401921
Tempature Sensor Set Multi D/A 1/8PT Optional Water or Oil Temp Set 16401922
EGT Sensor Set Multi D/A 1/8PT Optional Exhaust Gas Temp Set 16401923
Boost Sensor Multi D/A 4mm Dia Replacement Boost Press Sensor 16401900
Pressure Sensor Multi D/A 1/8PT Replacement Oil or Fuel Press Sensor 16401901
Tempature Sensor Multi D/A 1/8PT Replacement Water or Oil Temp Sensor 16401902
EGT Sensor Multi D/A 1/8PT Replacement Exhaust Gas Temp Sensor 16401903
Boost Sensor Harness Multi D/A 1.5m Replacement Boost Press Sensor Harness 16401910
Pressure Sensor Harness Multi D/A 1.5m Replacement Oil or Fuel Press Sensor-Harness 16401911
Tempature Sensor Harness Multi D/A 1.5m Replacement Water or Oil Temp Sensor Harness 16401912
These will be in stock and ready to ship as soon as Greddy receives them in early July.
We will be placing pre-orders from now till they are in stock.
Gauges start as low as $405 W/ FREE 3day shipping.
- Numeric and Bar-graph digital readout can display 2 additional readings
- Selectable 7-color LED Backlighting (white, yellow, green, blue, light-blue, purple, red)
- Animated Start-up Sequence
- Peak Hold Recall
- Warning Point Alarm
- LED Illuminated back Logo
- Voltage reading via power harness
- Water-resistant Center Unit, labeled and pre-wired for optional sensors
Looks like Dynamic Autosports is doing Giveaways for the month of August. All you have to do is go to this link:
HERE
Click "LIKE" on any of the pictures that you want to win. At that point you are entered to win at the end of the mont. we will have a drawing here and contact you via facebook when you win! good luck everyone!
HERE
foxbear2277
Dec 15, 2013 05:49 PM
blonde
Dec 1, 2005 06:31 AM
