COSWORTH - M3 "Race" Cams for IX
Old Feb 25, 2008 | 11:44 PM
  #31
06ravenmr's Avatar
i purchased a set of these cams as well. just curiouse of if im gonna be losing power going with the m3 cam over the m2. or will i just not see the full benefit of the m3 cam until i upgrade the turbo? r those dyno numbers before tuning or after?
Old Feb 26, 2008 | 08:16 AM
  #32
ecuflasher's Avatar
The M3 cams look to be the best of both worlds....gains in both midrange and topend power! However it just came to my mind...how abt the torque curve? Did these cams lose midrange torque or spool?
Old Feb 26, 2008 | 08:36 AM
  #33
EvolvedGTI's Avatar
pm'd
Old Feb 26, 2008 | 09:28 AM
  #34
Magnumpsi's Avatar
Hey guys,
The test car was tuned for the cams. As for the torque charts there isn't any loss over the M2's in terms of your tourque curve.
These cams will give you power regardless of the turbo set up. Stock turbo they would make some great power but they would really shine for you guys that have bigger turbos.
Hope this helps a bit guys,
Mitch Mckee
Old Feb 26, 2008 | 08:11 PM
  #35
ecuflasher's Avatar
So the test car had the stock turbo on at the time of the test or something bigger?
Old Feb 26, 2008 | 08:39 PM
  #36
06ravenmr's Avatar
Originally Posted by Mitch@VividRacing
Hey guys,
Mitch Mckee
thank you for the info. sounds like a made a good choice in cams. i can make good power on my stock setup and even better power when i go with my 37r.
Old Feb 27, 2008 | 05:27 AM
  #37
joedr's Avatar
EvoM Moderator
pm me price shipped to 00728!
Old Feb 27, 2008 | 09:51 AM
  #38
Vivid Racing's Avatar
PM sent.
Thank you
Jon
Old Feb 27, 2008 | 01:12 PM
  #39
joedr's Avatar
EvoM Moderator
Quick Question! I noticed that on the second pull (M3 cams), it says "cos 280/272 after timing 2".
Does that mean that they retarded/advanced the exhaust cam? Also, does the MIVEC table stayed the same for both pulls?
Old Feb 27, 2008 | 03:10 PM
  #40
Magnumpsi's Avatar
I would imagine that the MIVEC was kept the same. I am sure with more MIVEC tuning you could achieve even more power.
This has no cam gear on the exhuast just a revision number.
Mitch
Old Feb 28, 2008 | 12:40 AM
  #41
dxbevo9's Avatar
do you have those cams in stock...
i need those + valve springs + retainers shipped to dubai Mitch..ASAP
Old Feb 28, 2008 | 04:25 PM
  #42
The cams are out of stock at the moment. BUT YGPM
Thank you
Jon
Old Mar 3, 2008 | 05:41 PM
  #43
MORE CAMS ARE IN STOCK!!!!!!
Jon
Old Mar 5, 2008 | 06:30 AM
  #44
ecuflasher's Avatar
Still interested in these cams. Can you confirm if the M3 intake cam with its 11.6mm lift is a direct 'plug and play' without us needing to check the piston to valve clearance?
Old Mar 5, 2008 | 04:11 PM
  #45
Cosworth only recommends doing a valve spring up-grade with this cams.
regards
Jon
