EVO 8 - Got Cams???
Old Feb 25, 2008 | 06:07 PM
Vivid Racing's Avatar
Exclamation EVO 8 - Got Cams???
Hello All!!
For those of you looking to get a great set of cams at a very affordable price for your EVO 8, I got the solution. We have received a shipment of XS Engineering Race Cams for the EVO 8.
Here are some specs!
XS Engineering RaceMax Camshafts: 2003-05 Mitsubishi Lancer Evolution 8
SKU#XS51-1000
LIST PRICE: $658.90
VR WEB PRICE: $419.99
EVOM MEMBER: PM FOR PRICING
MORE PRODUCT DETAILS
Have you ever heard of a win-win situation? Well our RaceMax 272 degree camshafts provide exactly that! Sold ONLY in pairs, these camshafts allow your EVO 4, 5, 6, 7, or 8 to make power EVERYWHERE in the powerband. That's right, from 2000rpm to over 7500rpm our camshafts make more power and torque even with a stock turbocharger. There is no longer any need to "stagger" your camshaft selection for a"better idle" or "to keep some low end power" because these camshafts do it all and have been engineered to work as a pair. Your engine will hit peak boost up to 350rpm earlier reducing turbo lag and increasing throttle response which means this is an engine modification you can feel instantly. At 3500rpm, a gain of 31.9 hp at the wheels will definitely push you back in the seat. Just look at the chart below or view the dynosheet to see the power gains.
These camshafts have just a little more lift than the popular HKS camshafts and the same duration. Operation below 7500rpm does not require valve springs or retainers as the factory valve springs and retainers are plenty strong to prevent valve float. However, if you plan on running your engine at sustained speeds in excess of 7500rpm for extended periods of time, we recommend installing the Crower valve springs and retainers.
These camshafts are machined from new forgings and will bolt-in directly to your head. Cam sprockets can be used to fine tune the powerband, but these camshafts have been optimized to work perfectly with a stock deck height and un-machined head (meaning a stock engine that hasn't had any machining operations to remove any material). Any changes in block deck height or head surfacing will require adjustable cam sprockets to re-optimize the cam timing. ECU tuning is required to squeeze the most out of these cams, but is not required. However, any modifications to today's engines will greatly benefit from ECU tuning. A capable tuner and ECU will bring the best out of any modification with optimized fuel and ignition advance maps. With a good tune, these cams can idle very close to stock at 800rpm. If you have or plan on getting a flashed ECU, make sure to let your tuner know so they can stabilize your idle properly.
Our engineers have spent hundreds of hours developing the perfect camshafts for the EVO8. Here's your opportunity to have a piece of that perfection.
Dynosheet Info:
Dyno passes were performed on an EVO 8 with a stock 4G63 engine, stock head, stock turbocharger, XS RaceMax downpipe, XS RaceMax cat-delete, HKS RS Intake, HKS Hiper cat-back exhaust system, XS PowerIC front mount intercooler kit, XS RaceMax hardpipe kit, HKS EVC E-Z boost controller set at 1.5kg/cm2 (21.3 psi), HKS V-Pro ECU (v3.1), 1000cc x 4 RC Engineering injectors,Walbro 255lph fuel pump, 10.5:1 A/F ratio, and California 91 octane pump gasoline. Greater gains can be obtained on 93+ octane pump fuel in other states and countries or with race fuel.
RPM-------Stock (whp)--------w/ RaceMax 272-------Gain (whp)
2500-------- 82.0-----------------------89.1---------------------------7.1
3000--------116.2--------------------135.2--------------------------19.0
3500--------169.5--------------------201.4--------------------------31.9
4000--------237.1--------------------247.5--------------------------10.4
4500--------262.8--------------------271.6--------------------------8.8
5000--------275.0--------------------287.8--------------------------12.8
5500--------295.3--------------------305.0--------------------------9.7
6000--------308.9--------------------317.9--------------------------9.0
6500--------315.8--------------------328.8--------------------------13.0
7000--------319.0--------------------331.9--------------------------12.9
7500--------318.0--------------------330.0--------------------------12.0[/B]
For installation instructions go HERE!!!!!!!
To check out other sweet cams and products for your EVO 8 go HERE!!!
SKU#XS51-1000
LIST PRICE: $658.90
If you have any questions or need to place an order, just send me a PM, or E-mail or call direct at 480-966-3040 ext:230
Thanks for looking!!!!
Old Feb 26, 2008 | 12:09 PM
BUMP!!!!
Jon
Old Feb 28, 2008 | 01:48 PM
BUMP!!!! Some shipping out today. Price too good to pass up!!
Jon
Old Feb 28, 2008 | 02:50 PM
Slo_crx1's Avatar
Interesting...another contender on the market. How would you personally compare these to a set of GSC S1's in power production? And pm me a price too if you could
Old Feb 28, 2008 | 03:17 PM
You Got PM
Thank you
Jon
Old Feb 28, 2008 | 03:19 PM
EVO Scotland's Avatar
they seem quiet good, fast spool
Old Feb 28, 2008 | 03:48 PM
Yup, they are very nice cams.
Jon
Old Feb 29, 2008 | 09:44 AM
esevo's Avatar
I have personally had these cams on my Evo8! They were much better than the HKS 272's I had before!!! I would highly recommend these cams to anyone!!!!
Old Mar 1, 2008 | 03:01 AM
so are these like the GSC1's???
Old Mar 1, 2008 | 07:32 AM
tbwillie50's Avatar
would also like to know compared to gscs1
Old Mar 2, 2008 | 02:42 AM
bump
Old Mar 3, 2008 | 07:41 AM
don't think they are as good as the s1 tbh
Old Mar 3, 2008 | 08:24 AM
We have not done a comparison between the two, so I wouldn't be able to tell you if they are better. Both are great cams, I haven't heard anything bad about either so I guess that's a good thing.
Regards
Jon
Old Mar 4, 2008 | 02:22 AM
they seem to spool quicker! any more graphs??
Old Mar 4, 2008 | 08:33 AM
Sorry I don't have any more graphs, unless someone in the forum has a set on their car and does have a graph to share.
Regards
Jon
