FS: Fully Built Shortblock
Fully built 2003-2006 Evo 8-9 block, ready for up to 1000hp+
EAGLE FORGED CRANK
MANLEY IBEAM TURBO TUFF 14403-4
JE CUSTOM 9.0:1 +.40 PISTONS
COSWORTH MAIN BEARINGS
ACL THRUST BEARINGS
COSWORTH ROD BEARINGS
ARP MAIN STUDS
AMS RACE CONCENTRIC OIL PUMP SHAFT + ELIMINATOR
CLEAN AND CHECK
BORE AND HONE
DECK BLOCK
SET RING END GAPS
LINE HONE MAINS FOR ARP MAIN STUDS
PISTON TO ROD ASSEMBLY
ASSEMBLE ROTATING ASSEMBLY
BALANCE SHAFT ELIMINATOR INSTALL
BLOCK
READY FOR INSTALLATION.
$4300 firm
More TTP engines now available!
Now available with Groden Lightweight Aluminum Racing Rods!
EAGLE FORGED CRANK
ACL THRUST BEARINGS
ARP MAIN STUDS
CLEAN AND CHECK
BORE AND HONE
DECK BLOCK
SET RING END GAPS
BLOCK
$4300 firm
EAGLE FORGED CRANK
ACL THRUST BEARINGS
ARP MAIN STUDS
CLEAN AND CHECK
BORE AND HONE
DECK BLOCK
SET RING END GAPS
BLOCK
$4300 firm
The one pictured had a forged crankshaft and AMS concentric shaft/ balance shaft eliminator kit.
If someone has a good crank and block core, the cost goes down considerably.
We have aluminum Groden lighweight racing rod motors as well as steel Ibeam rod shortblocks available in the $3k range with good core.
For more TTP Stage III Racing Shortblocks, see this thread!
https://www.evolutionm.net/forums/ve...e-program.html
