Engine Dampner for your EVO 8
Old Oct 15, 2004 | 11:26 PM
  #76
GannerBoy's Avatar
Anyone else have trouble removing the engine mount bolts that mount the L-bracket? Any tips?
Old Oct 16, 2004 | 01:04 AM
  #77
simevo's Avatar
Just use an extender with a long socket wrench to get the extra torque. But to reach the bolts, you need to unbolt the mounting bracket for the power steering line and just push the line away to reach the bolts.
Old Oct 16, 2004 | 11:19 AM
  #78
LateSleeper's Avatar
Just kind of curious on the bracket mounting points. Do you guys think that they are safe to handle the load of the engine moving back and forth? I am intersted in the part.
Old Oct 16, 2004 | 01:37 PM
  #79
simevo's Avatar
It should be safe since the dampner will take the most of the heavy shock since it's not a solid metal rod but more like a suspension shock.
Old Oct 16, 2004 | 08:03 PM
  #80
JasonS's Avatar
no trouble with the engine mounts, but I did have some issues with the hard a/c lines and moving them to fit the dampner brackets. I flipped the upper A/C mounting grommet to move the a/c line lower, and no problems now.
Kudos to prostreet for getting out my dampner quickly and without any problems!
Old Oct 16, 2004 | 09:12 PM
  #81
Karash's Avatar
I would really like to see these for the other side as well...any word on this?
Old Oct 17, 2004 | 03:20 AM
  #82
GannerBoy's Avatar
This thing is amazing... I can shift so smoothly now and when I turn off my car I don't hear my engine rocking back and forth, I just can't believe such a small thing can change so much driveability.
Old Oct 18, 2004 | 04:59 PM
  #83
ProStreetOnline's Avatar
Should have no problems. The torque is set high from the factory, just get a nice breaker bar to break them free
Old Oct 18, 2004 | 05:00 PM
  #84
Absolutely.
Old Oct 18, 2004 | 05:02 PM
  #85
With how well just one works, Weapon R does not have an interest right now in creating one for the other side... If they release one, or want to, we will donate an EVO to them for testing, and release it here.
Thanks!
Old Oct 18, 2004 | 05:03 PM
  #86
Yep! This is definately a great product, we are proud our customers are happy
Thanks guys!!
Old Oct 20, 2004 | 12:11 PM
  #87
Bump!
Old Oct 22, 2004 | 04:18 PM
  #88
stvbreal's Avatar
I want to add one more thing. After drving around for a few days/week I noticed something. I never paid attention to it because I was getting used to this noise. When sitting at a light (stopped) the rattling sound from the throwout bearing (I believe this is where most people are getting this noise from at idle) went away. Now, I'm not sure if the the damper has anything to do with it but hey, it made the noise before I installed it. And now it doesn't. Coincidence?
Old Oct 23, 2004 | 03:38 PM
  #89
MattGold's Avatar
Just installed mine and yes it is prety straight forward... but am I missing something when "tightning" the dampner?
If I tighten it one way (i.e. thread it into the schock mount) then is UNTHREADS from the engine mount, and vise versa. I can get it in both, but there are MANY thread exposed on both ends... I feel like the pistons part of the "shock" doesn't extend enough to allow full tightning.
Any tips?
-M
Old Oct 23, 2004 | 04:40 PM
  #90
MattGold's Avatar
Nevermind.. I just had to rotate the plate under the strut bar.
-M
