HKS Cam Gears blow out!!!
Hey guys,
We got way too many HKS cam gears in stock and now we need to blow them out!!! Take advantage of this Christmas special! Our special price is $250 for a pair SHIPPED!
Specs/Info:
HKS Adjustable Cam Gears allow for fine tune adjustments to cam timing to maximize engine performance and tailor power characteristics for various driving conditions. Either with OEM or HKS Camshafts, adjustments can be made to tune an engine’s powerband to an optimum RPM range for a particular application. By using a Vernier scale, a valve timing adjustment tool that uses sub scale, a more accurate adjustment is possible because it provides the crank angle in 0.2 degrees increments. HKS cam gears are constructed of anodized precision-machined aluminum plates and incorporate laser-etched indexes in 2 degrees intervals. The full aluminum versions of the HKS Cam Gears are constructed completely of aluminum (except for the bolts), thereby reducing overall weight and resulting in decreased friction loss and greater precision timing. Precise valve timing can be adjusted and set within the range of ± 20 degrees in 2 degrees intervals by referring to the laser-etched degree indexes and the “A” (advance) and “R” (retard) directional etchings on the cam gear face
Please give me a call to order!!!!!
Thanks!
Cal
Specs/Info:
Thanks!
Cal
