GSC 272/264 Combo with Studs $580 Shipped!!
Originally Posted by sleet
I can't decide which setup to go with, the 272/264 or straight 272s. I don't plan on upgrading my turbo anytime soon unless somthing amazing comes up
My car will be daily driven but I will drag race at the track and whatnot. Which setup would help me more in the 1/4th?
My car will be daily driven but I will drag race at the track and whatnot. Which setup would help me more in the 1/4th?For stock turbo and your driving sounds like the 272/264 would work best for you. You can always swap out the 264 cam if you upgrade your turbo,
Chris
Hey Chris, is it possible for me to exchange my 272 exhaust cam for a 264. The cam is still brand new, never even taken out of the box. I dont plan on upgrading my turbo, so i dont think straight 272s are necessary since my car is daily driven. I'm not sure how u want the exchange to go down, so let me ASAP. Thanks, Ryne.
Chris
I must start with the service from these guys is Topnotch...even called me back on the phone to make sure I had all the info I needed....Now on with the cams...I installed these this weekend alongwith ACT clutch that I also got from Logic..272in/264ex is incredible....the torque improves over 80lbs from 3100 to 3500 and max torque is at 3500 holding strong to 6K where a high HP number takes over....They produced 337hp and 311tq with stock injectors and intercooler at 20psi...I am fairly happy...I recommend these HIGHLY!!Idle does sound like a V8 monster though, Intimidating!! I guess I better add that we did not try and smooth out the isle so I am sure it is easily possible, I just like it to lope a little..
Chris
Nice #'s
Originally Posted by dadriva
Any additional tuning required after installation? Or just install and haul.
Also, valve adjustment differences?
Bit of an Evo noob, getting info together, thanks!
Chris
Only 272/264 available in the country don't be fooled by other vendors!!
