NEW PART!! Bolt on FPR w/Gauge!! Ready to ship!!
Old Apr 11, 2005 | 01:15 PM
TalonRcR's Avatar
Thumbs up NEW PART!! Bolt on FPR w/Gauge!! Ready to ship!!
If you have an aftermarket fuel pump or are interested in proper tuning, you need an adjustable fuel pressure regulator. Until now that meant having to adapt and cobble up some fittings that look bad and are complicated to install, may require some welding or epoxy (you going to trust a fire to some epoxy?).
Our all new billet regulators just bolt on in place of the stock unit.
NO complicated plumbing needed.
NO modifications
NO Special tools
Most aftermarket pumps will outflow the stock regulator, this overrun condition will cause idle fuel pressure to run high and effect the tune up and performance of your car. It can also effect milage and drivability. If you have a MAFT or an AFC the tuning will be much easier when the fuel system is in control. This unit also has a 1/8 NPT port on the side for easy hook up to a FP gauge. Comes with all hardware to install and a money back guaranttee if you are not happy, that is how sure we are about this quality unit!
Click to Order!! 169$!!
Thanks
Chris
Old Apr 11, 2005 | 03:40 PM
bryans2k's Avatar
what size inlet/outlet does it have?
bryan
TalonRcR's Avatar
These have been backordered for ever get yours while you can!!
Chris
Old Apr 11, 2005 | 03:45 PM
TalonRcR's Avatar
bryan
Outlet bolts right to your fuel rail same size connection. 3/8" Barb fitting inlet.
Chris
Old Apr 12, 2005 | 08:29 AM
TalonRcR's Avatar
Ready to ship!!
Old Apr 12, 2005 | 08:32 AM
smackdaddy's Avatar
does this include the gauge, or just provide a 1/8 npt for a gauge to be tapped into, or both? This is obvious, but I'll ask anyway, this is a rising rate fpr 1:1 right?
TalonRcR's Avatar
Originally Posted by smackdaddy
does this include the gauge, or just provide a 1/8 npt for a gauge to be tapped into, or both? This is obvios, but I'll ask anyway, this is a rising rate fpr 1:1 right?
Comes with gauge look at the title of post. Yes rising rate.
Chris
Old Apr 12, 2005 | 08:35 AM
Kbp2025's Avatar
How long are you holding this special for??
Old Apr 12, 2005 | 08:37 AM
TalonRcR's Avatar
Till there gone. got 9 left.
Chris
Old Apr 12, 2005 | 01:54 PM
TalonRcR's Avatar
Thanks for all the orders got a few left!!
Chris
Old Apr 13, 2005 | 02:29 PM
TalonRcR's Avatar
Plenty in stock..
Old Apr 16, 2005 | 09:07 PM
TalonRcR's Avatar
Bump for great deal!!
Old Apr 16, 2005 | 11:14 PM
ElAnCeR's Avatar
bump for great seller
Old Apr 17, 2005 | 08:50 AM
bdking57's Avatar
Just purchased one..Is this a simple bolt on I can do myself? It peforms essentially like stock however can regulate higher fuel line pressure from the walbro 255 correct?
Old Apr 17, 2005 | 08:57 AM
TalonRcR's Avatar
Yes you are correct.
Chris
