Perrin Exhaust Clearance
Old May 19, 2005 | 01:07 PM
Vivid Racing's Avatar
Perrin Catback Exhaust
The PERRIN Performance™ Evolution exhaust emanates style and performance.
The PERRIN Performance™ Evolution cat back exhaust system is constructed of full 3" diameter, CNC mandrel bent, 304 stainless steel. This fully flanged complete cat-back unit insures leak free function. The PERRIN™ exhaust system bolts directly on to stock and aftermarket down pipes using all existing mounting hangers. The straight-though, huge, 3.5" inside diameter PERRIN muffler creates maximum performance and horsepower while emanating a deep exhaust note.
This PERRIN" exhaust features a single, 4", slash cut, stainless steel tip and a high polish, strait through muffler. The PERRIN Performance" Evolution Exhaust is constructed of full 3"
$600 plus shipping
Perrin Downpipe
The PERRIN Performance™ Lancer Evolution VIII down pipe will increase spool up speed and horse power. The PERRIN™ down pipe is formed from mandrel bent 3", 304 stainless steel tubing. Reaching from the turbo manifold outlet to the catalytic converter this down pipe c an work with stock catalyst or our cat-delete pipe. The PERRIN Performance™ down pipe requires only minimal changes in underbody clearance. To maintain a proper gasket seat the PERRIN™ down pipe is made with 1/2" thick stainless steel flanges. By reusing a stock style donut gasket the PERRIN™ down pipe maintains proper seal to turbo outlet allowing proper movement of exhaust system under acceleration and deceleration without stressing the turbo, manifold or welds. The entire PERRIN™ down pipe is TIG welded for proper bonding and minimal flange and pipe distortion.
Will fit for 03-04 (05 need custom work)
$280 plus shipping
Perrin Cat Delete Pipe w/Cel Eliminator
The PERRIN Performance™ O2 simulator is for those consumers using components, which alter the signal of the rear O2 sensor causing the check engine light. The PERRIN™ O2 Simulator attaches into the vehicles wire harness simulating the natural operations of an oxygen sensor fooling the ECU turning off the check engine light. Drag strip and track racers will now have the ability to bypass restrictive emissions equipment allowing them to use aftermarket products for more horsepower and performance.
$160 plus shipping
Perrin Turboback Exhaust
You get the Perrin Performance 3 inch downpipe, the 3 inch cat delete pipe, and the 3 inch catback system giving you a full stainless steel 3 inch turboback system.
What is best about the Perrin system is that the cat delete pipe includes a CEL eliminator...NO MORE CHECK ENGINE LIGHT! The exhaust is a single 4 inch tip straight through design for a great sound. The pipes are all mirror polished, except the downpipe. This setup should gain you about 20+ wheel horsepower on your EVO VIII.
$905 plus shipping
Questions or Orders, PM me or give me a call at 1.866.44.vivid ext 226.
Jacky
Vivid Racing
Evo 'For Sale' Miscellaneous
23
Oct 3, 2007 11:00 AM
Vivid Racing
Dec 21, 2005 11:51 AM
Vivid Racing
Nov 29, 2005 12:23 PM
Vivid Racing
17
Nov 28, 2005 03:48 PM
