Agency Power Short Shifter
Agency Power has always focused on real racing performance. With its strong alliances with some of the fastest EVO VIII's on the tracks, Agency Power has finished testing and is proud to release its brand new short shifter for the 2003 and up Mitsubishi EVO. This 5 speed short shifter is designed to give you a fast, clean, and precise shift that the stock shifter lacks, and the competition tries for.
The shifter reduces the throw about 35% compared to the factory shift lever. In addition, the shifter height is lowered about 15mm for a sport feeling to help you get through the gears more efficiently. The CNC machined short shifter is made from 1018 High Strength Steel. The lever is then zinc coated in black for a stylish stealth look.
This short shifter is a perfect addition to your high performance or off the lot Mitsubishi EVO. Whether you are road racing, drag racing, or daily driver this shifter will improve your driving success.
$129.99 Free Shipping
Questions? Orders? Email me or call me at 1.866.44.vivid ext 226.
Jacky
From: driving the 10 second beast in ohio or running lightmods.net
bump for lots of great results with this shifter setup!! here is some info on what i have achieved thus far with it!
https://www.evolutionm.net/forums/sh...+short+shifter
read down i ended up using the agency its great!
a good short shifter designed properly as this one has will not cause anywhere.....i have used tons of them on tons of cars and some had problems but this won't if you know how to use it.
shifts flawless for us...
https://www.evolutionm.net/forums/sh...d.php?t=153046
The only thing you might want to buy is a new bushing depending on the wear of yours. Yes the stock knob fits right on. It was designed to be a direct replacement.
P.S. there is about 20-30 instock
It the moment we do not have one available. I will post when it comes out. It is already in the works, but we need to fit and test before they are made available for sale. Thank you for the inquiry. Until then i will keep my eyes open for any options that do become available.
