Espelir, Perrin, JIC Turboback Combo Returns
Espelir/Perrin Combo (***Espelir DP will fit 03-04 Evo's only)
a complete turboback system.
This deal is good until i run out of Stock
What you will recieve:
Espelir Catback Exhaust
Espelir Downpipe
Perrin Cat Delete Pipe w/cel fix
A Complete TurboBack System!
$810 plus Shipping ($50-65)
The all new Espelir Exhausts from Japan have arrived and now available for your high performance tuner car. The exhausts are stainless steel, mandrel bent, straight through mufflers, include gaskets and silencer. The system is a complete bolt on and has a 3 year warranty from manufacturer defects. Vivid Racing is an authorized USA supplier for all your Espelir needs. The pipe diameter is 80mm with a 115mm tip.
Espelir Downpipe
Japanese tuning power Espelir has just released a brand new Downpipe for the Mitsubishi EVO VIII. This downpipe is full stainless steel with thick flanges and tig welded hangers which give the downpipe a perfect fit. The turbo to downpipe flange uses the factory donut gasket. The diameter of the downpipe is 3 inch for best flow. The downpipe gains about 12 whp and fits with the stock cat pipe or aftermarket cat delete pipes.
The Perrin cat delete pipe is used to replace your stock catalytic converter for added performance. Simple bolt on performance easily pumps up the horsepower out put of your Evo in seconds. Constructed of all stainless steel materials. 3” 304 stainless steel tubing. 1/2 inch stainless steel flanges.
The Perrin Cat delete pipe has a strait through design and is a full 3 inches in diameter. Any smaller and you pinch off the exhaust gases. Larger and you create a pressure drop.
The Perrin cat-delete pipe is produced exclusively from 304 stainless steel. The 3 inch center section has no bends for a strait through, high flow design. Stout 1/2 inch flanges are used to prevent any warping from high temperatures. (Unusually high temperatures can occur from use of a larger turbo or under racing conditions.) Finally the entire piece is polished to a mirror finish.
The Perrin Performance cat delete pipe is the first to come with an O2 simulator. The Perrin Performance O2 Simulator attaches into the vehicles wire harness simulating the natural operations of an Oxygen sensor. Your computer will not know that you have removed the vehicles catalytic converter.
If you own a 05 or a Evo MR then we can replace the Espelir DP with a JIC DP that will fit and clear on the 05 and MR's
$880 plus Shipping ($50-65)
Individually:
Espelir Exhaust $479.99
Espelir Downpipe $179.99 (free shipping)
JIC Downpipe $244.99
Perrin Cat Delete Pipe $170.99 (free shipping)
Questions? Orders? Pm or call me at 1.866.44.vivid ext 226. If i am not here then please leave a message. I am most likely in class and check my voicemail through out the day.
Jacky
Espelir Downpipe
Espelir Downpipe
Individually:
Jacky
