Nisei Engineering Intercooler Pipe Kit RELEASE!!!
Old Sep 10, 2005 | 01:30 PM
myevostore.com's Avatar
That's right everyone! The long awaited pipe kits will be shipping tuesday/weds of next week!! Since there's a HUGE demand for these, we're taking $100 deposits to secure your position in the first batch, which will consist of about 20 - 25 kits.
For those who haven't been following along in the development of the kit, here are some details below:
  • Pipes made of 6061 Aluminum, mandrel bent for the shortest possible distance.
  • Piping consists of all intercooler piping on both hot and cold sides.
  • Kit includes super strong multi-layer silicone couplers and t-bolt hose clamps.
  • Entire kit, including all hardware, clamps and couplers weighed in at 4.3lbs!
  • Kit works flawlessly with the stock intercooler or the acclaimed Nisei FMIC.
  • Pipe kit requires the use of a mini battery kit or trunk relocation!
  • Option will be available for a bung pre-welded on for the EMS Air Intake Temp sensor.
  • Works with the stock blow off valve or any valve that works in the stock location or you can request a specific flange welded on the kit for use with your favorite BOV.
  • Fully compatible with the stock airbox!
The price for the kits will be $480 including all hardware and everything you need to get it in your Evo! For the first batch i'll be paying for your shipping in gratitude for being so patient during the creation process. Kevin told me for those who pre-order may get a discount, I will ask him about this next week as well.
Color choices available are polished, Nisei black, and the stealth "raw" aluminum finish with clear anodizing (for those that want the stock look). More details on raw will be available next week along with photos.
You can place your deposit at myevostore.com using the following link...
http://www.myevostore.com/product_in...roducts_id=348
If you hve any question please post in here!
I've attached some pre-production photos for you to check out!
Old Sep 10, 2005 | 01:40 PM
2befast's Avatar
when you say hot and cold sides, are you refering to upper and lower intercooling pipes.
Old Sep 10, 2005 | 01:55 PM
hueman's Avatar
these hook up to the stock ic locations? can we purchase just the upper or lower by themselves?
Old Sep 10, 2005 | 01:59 PM
djmikeymike's Avatar
^^^ i need the lower!!!!
Old Sep 10, 2005 | 02:00 PM
Yes, exactly.
Old Sep 10, 2005 | 02:04 PM
It does work with the locations on the stock FMIC if you are to use the stock 45 degree couplers. So if you have an aftermarket intercooler that works with the stock intercooler piping, this pipe kit should fit.
At this time, at least for the first and second run probably, we aren't selling the pipes individually. Once the demand has been met and we aren't swamped with orders we'll likely be releasing the pipes individually.
Rob
Old Sep 10, 2005 | 02:09 PM
import_junkie's Avatar
the intercooler and piping looks sweet compared to stock. i'm going to have to look into getting these.
Old Sep 10, 2005 | 05:02 PM
Thegame's Avatar
I like the fact that the pipes actually bolt up to the frame of the car like the stockers. I didn't like the idea of using aftermarket ic pipes that would just kinda flop around... And they do.
Old Sep 10, 2005 | 05:16 PM
Dave2's Avatar
can anyone show me the rear view of the Nisei FMIC ? Does the lower IC pipe including the part connected with the turbo?
Old Sep 10, 2005 | 09:37 PM
BBYBruno's Avatar
myevostore. Can you please pm me a price shipped to 44095; Nisei IC & piping, and mini battery kit, please do the best you can thank you!
Old Sep 10, 2005 | 09:41 PM
carbonevo8's Avatar
you've got pm
I'm also looking for a total kit price
Old Sep 10, 2005 | 11:59 PM
BBYBruno's Avatar
Bump for the new Nisei Piping!
Old Sep 11, 2005 | 03:43 PM
bryans2k's Avatar
how would it fit with the magnus intake manifold?
thanks,
bryan
Old Sep 13, 2005 | 06:12 PM
As long as the intake manifold preserves the positioning of the throttle body inlet, it should create no problem. From experience though, sheet metal intake manifolds sit super low compared to stock since they shoot straight out of the head instead of curving upward. You will probably want to ask Marco at Magnus.
Old Sep 13, 2005 | 06:40 PM
htsai14752's Avatar
will this fit with stock airbox?
