Forge MBC and BOV blow out sales !!!!!
Guys - I have dozens of Forge UNOS MBC - the best in the world boost control for your evo - - $85.00 shipped anywhere - silver polished and black in stock - paypal@dynoflash.com
I also have the amazing - second to none Forge RS BOV's In stock and ready to ship - I have the rare black and polished in stock
The Forge RS valve has been specifically designed and engineered, to offer extreme flow rate capability, where other valves are just not up to it. Often when engines have been tuned by installing larger turbos or even software upgrades improved turbo response can be acheived by fitting the RS valve which has the greater internal mass air flow specification utilising an amazing 50mm (2") bore.
For fine tuning there is a variable spring preload incorporated and a ratchet type top adjuster that will allow for the positive and precise adjustment that your driving style demands. To ease installation a 360 degree adjustable vacuum hose connector
With a choice of inlet and outlet connections the RS valve can be matched to your engine perfectly
This valve incorporates a unique conical, progressive rate spring that can allow for the retention of boost pressure from 7 to 34 PSI depending on the individual user's application and level of adjustment. This allows the end user to custom tailor the valve to his / her own driving preference. This unit can dial out compressor surge and smooth out a car in a few quick turns of the valve.
This unique spring design will also allow for unrestricted piston travel and flow volume regardless of the amount of pre-load adjustment added to the spring. Other manufacturers valves using cylindrical springs with adjustable pre-load often experience restricted piston travel and flow volume within the normal range of valve adjustment
I am blowing these BOV's out at a price TOO low to publish - PM me for a price quote
Happy holiday
Happy holiday
Happy holiday
Happy holiday
Originally Posted by Stew
Does the Forge MBC come with a mounting bracket?
