Helix Cam Gears,Methanol/Alcohol Injection Kit and engine exhale package!!!
Old Feb 14, 2006 | 06:10 PM
Gruppe-S's Avatar
1) Helix Cam Gears (pair)
Helix Power is pleased to announce the release of its 5-bolt cam gears for the Mitsubishi Lancer Evolution VIII (4G63). The Helix 5-bolt cam gear is CNC machined for T6061 Aluminum, anodized, and laser etched for accuracy. Unlike the 3 bolts design, the 5-bolt design will ensures precision and stability. The use of Helix cam gears allow 4G63 owners to adjust their camshaft timing to maximize power throughout the power band for many different applications. Adjustments are +/- 12 degrees.
189 + shipping!
2) Methanol Kit Special.
We are offering the Snow Performance EVO kit which is designed specifically for the EVO. An extremely high quality kit, this kit features built in failsafes that many other kits on the market simply don't have. Features include MAP based methanol injection, boost cut upon low methanol pressure, and extremely accurate injection volume.
Includes Boost Cut Failsafe System!!
We are offering this kit at $525 shipped
(You MUST mention this ad!)
Also, we still have our:
3)"Engine Exhale Package"
Some of the most restrictive components in your exhaust stream include the stock headers, 02 housing, and cat. We have packaged together a combo that is simplly unbeatable in price!
COMBO #1 - ~15-20whp gains
Maxford Exhaust Manifold + Helix 02 Housing + Helix Cat-Delete $425 Shipped!!! ($550+ sold individually)
COMBO #2 - ~8-10whp gains
Maxford Exhaust Manifold + Helix 02 Housing $375 Shipped!!!
Sold Individually:
*Maxford Header - $225 Shipped
-CNC Billet Flanges
-3mm Thick SS304 Tubes (yes that's right, one of the thickest on the market)
-TIG welded
-we have seen over 20whp gains on the Garret GT3076 turbo with this manifold!
*Helix 02 Housing - $199 Shipped
-SS304 Stainless construction
-Larger outlet port, larger wastegate dump area
-Significantly increases turbo response and spool time
*Helix Test Pipe - $129 Shipped
-Full SS304 construction, TIG welded
-Removes factory cat for big power gains
-Legal for off-road use only!!
Customer Testimonial:
Testimonial from a customer who bought a Maxford header and O2 housing a few months back
Please contact us for ordering!!
Thanks!!
PM OR CALL!
thanks,
Daniel
www.gruppe-s.com
510-783-5300
510-783-4300 fax
Old Feb 14, 2006 | 07:31 PM
bluevo's Avatar
will the helix cam gears work/fit with HKS cams?
do you have timing belt and clear cam gear cover that you can send by this Friday to 33556?
Old Feb 15, 2006 | 11:23 AM
MeKilla's Avatar
Does the Helix IC pipe fit in the stock engine compartment? I know there are a few kits out there thats upper pipe does not fit around the battery. Any info would be helpfull. thanks.
Old Feb 15, 2006 | 02:11 PM
Gruppe-S's Avatar
Hey Mekilla
The Helix IC pipe will bolt right on!
its jus for the bov you'll need to weld a flange for it
Hey bluevo,
The helix cam gears will work/fit with the HKS cams!
Sorry but we dont ahve the timing belt cover and clear cam gear cover at this time.
Thanks,
Daniel
www.gruppe-s.com
Old Feb 15, 2006 | 03:35 PM
Gruppe-S's Avatar
ttt!
Old Feb 18, 2006 | 06:44 AM
ROGERV's Avatar
Snow Performance menthenol injection kit
can you post more info on the Snow Performance menthenol injection kit. THANKS!!!! pump psi?
Old Feb 18, 2006 | 08:24 AM
vone750's Avatar
man i want them cam gears how long with this deals last.
Old Feb 18, 2006 | 01:46 PM
Gruppe-S's Avatar
ROGERV - We are currently running 23 PSI, however to tell you the truth its all gonna come down to tuning your car with the methanol injection kit to make the most reliable power.
vone750 - This deal will last until we sell all of our helix cam gears in stock
Thanks guys!,
Daniel
Old Feb 20, 2006 | 01:20 AM
Gruppe-S's Avatar
bump~!
Old Feb 20, 2006 | 05:18 AM
SaOrlando's Avatar
the meth injection kit.....
is it stage 2 snow kit with the safeinjection failsafe and wastegate solenoid?
is there evo specific parts not listed on their website?
Old Feb 24, 2006 | 03:04 PM
Gruppe-S's Avatar
Sa Orlando - yes it includes the fail safe and wastegate solenoid
Gruppe-S
Jan 12, 2007 10:26 AM
Gruppe-S
29
Nov 30, 2006 12:18 PM
Gruppe-S
Aug 30, 2006 12:14 AM
Gruppe-S
15
Feb 2, 2006 01:31 PM
Gruppe-S
77
Dec 7, 2004 01:57 AM
