Dyno Flash "E FLASH!" now available
Old May 16, 2006 | 01:14 PM
  #61
hondafan's Avatar
Originally Posted by thekuai
yes the cable is just the interface between the ecu and a computer...doesnt have to be a laptop, you can run an extended usb cable to a computer.
so i can just run a 20ft USB cable through the window outside to the car!
Old May 16, 2006 | 01:36 PM
  #62
thekuai's Avatar
i dont think you can run a usb cable that long without attenuation problems...you would need some sort of a powered usb cable...but if it was just a joke teehee
Old May 16, 2006 | 01:41 PM
  #63
budlong's Avatar
AL,
can you do anything will the 03 intercooler sprayer button? Use it to instead switch between two of your maps?
i have to say.. for the price.. that is an incredible deal.
Old May 16, 2006 | 01:43 PM
  #64
ruchc03's Avatar
man, i have to get on this train!
Old May 16, 2006 | 01:52 PM
  #65
Doogie Howser's Avatar
**i'll take it to PM**
Old May 16, 2006 | 01:54 PM
  #66
donour's Avatar
Originally Posted by Doogie Howser
mac dl link?
What about the mac?
d
Old May 16, 2006 | 02:03 PM
  #67
I was kind of curious if I could get the software to work on mac osx and am still unsure. I'll continue to dig at the forums over at openecu.org, until I get an answer...
  #68
donour's Avatar
Originally Posted by pog0
I dont see why it wouldnt work with Apple computers. If you go to openecu.org there is a driver you can download for the USB cable to work with your system. I have downloaded the Evo 8 Software to my PB G4 and it seems to work fine. When IX software is available, I will try it on my car and PB.
There is not a port to OS X (even intel) yet. I've discussed the possibility with Colby already though. As it stands, the driver we need (the D2XX) has not yet been ported to darwin. There is a VCP driver, but I only got it working yesterday. I posted a directions on using it on the openecu forums.
I've also ported freediag to OS X so I can use it for OBD-II. However, the apple IOkit framework won't allow baudrates below 50, thus the obd-ii handshaking fails.
d
Old May 16, 2006 | 02:06 PM
  #69
ok thanks....looks like its time to pull out the ibm...
Old May 16, 2006 | 02:40 PM
  #70
MalibuJack's Avatar
Originally Posted by budlong
AL,
Nothing has been done yet to modify the function of the ECU, only to adjust parameters... so currently no you cannot do that..
However, I did suggest this idea to "poke information" into the octane trim, to force it to go to either one or the other map.. At the least that function can be used to restore a "Cranky ecu" to its high-octane map, another use would be to force using one or another of the maps, however that might remove your margin of safety that it offers..
In other words.. Time will tell, since their currently disassembling the code to find all the useful functions, and data, at some point they will be able to add or modify functionality. aka "code hacks"
Old May 16, 2006 | 03:00 PM
  #71
damianhindley's Avatar
I just tried the ecuflash program on my mac. it opens tries to open it as an exe file. so will not work. So yeah untill its made for mac i guess its a no go. oh poo. Look like a good program though, I just want it so i can set my launch control based on track conditions.
Old May 16, 2006 | 03:14 PM
  #72
MalibuJack's Avatar
You can run a PC emulator app, install a copy of windows XP or 2000, just make sure the emulator has USB passthrough so it sees USB devices plugged in..
I actually tried this on a machine (Windows server 2003) running VMWare, which has a USB passthrough and it works fine. Haven't tried a MAC running softPC or anything like that..
Old May 16, 2006 | 03:16 PM
  #73
Agent-Smith's Avatar
Get virtual pc or whatever to use it on a mac machine. NO garuntees the drivers will work but hey it is worth a shot.
Old May 16, 2006 | 03:20 PM
  #74
A418t81's Avatar
Excellent idea Al, even for the tinkerer, a $50 solid base from which to tweak is most definitely worth its weight in gold.
Old May 16, 2006 | 03:45 PM
  #75
MalibuJack's Avatar
If virtual PC creates a 100% compatible emulation environment, and it can passthrough USB (so it can detect plug and play devices) then it should work if you install Windows XP on the VirtualPC
