Dyno Flash "E FLASH!" now available
you guys have to read through the threads alittle more, I used als flash as a base, and been tweaking it ever since i got it. i have alotta faith in the Stock ECU, i never thought that i would fail ever since i kicked the utec out. there was never any need for a utec or safc, or anything of that nature. You just needed to do the research, ( which alot of people Dont DO!!!!) and figure out that ECUflash or a mail in flash will get you close or the same results that a UTEC safc, would, dont forget that all your piggy back ECU modifiers are just that..... PIGGYBACKS! they're still bound by the stock ECU. so by using your ecu flash youd still get the same results. Just a small observation
Originally Posted by ohio-evo
Just ordered my cable. Does anybody have a how to for downloading my ecu with ecuplus? Thanks for all your help everyone. I am a systems admin so don't be scared to get too techy on me.
Originally Posted by fsugatorbait
Originally Posted by MalibuJack
I have an ECU+ coming soon, I'll be contributing alot to both the flash and ECU+ forums on getting the two to work cooperatively..
Should be an unbeatable combo with ECU+ and ECUflash.
Originally Posted by JeffR116
With all of these projects you have going on, that website looks like it's going on the back burner.
Since playing with ECUFlash, I've turned off the Open-Loop fuel on UTEC. So now my UTEC works just like ECU+ on fuel adjustment, and I can have a static timing control where I want it. It works like a charm!
I am still using UTEC to control my boost now, because I am running Perrins EBCS. The way I hook it up will require UTEC or other EBC to control it properly. Anyhow, I think I will need to keep my UTEC for map switching feature, so I can run my SMC Alky. So yes, piggybacks like ECU+ and UTEC still have its place in the market. And they only work better with ECUFlash!
Yep. I'm keeping my Xede for nitpicky timing changes as well as to control the alky box when I finally pick one up. Nothing like having another computer sit there and watch both knock and AFRs looking for anything funny when spraying the meth
Oh yeah, and the ECU+ has some of the most impressive logging GUIs/setup I've ever had the pleasure to play with and tune on. I thoroughly enjoyed it. Hats off to the developer for such a great piece of software.
