Invidia O2 Housings In stock!!
We just got a batch of Invidia O2 housings in. If you do not know about them yet here is some info.
This turbo outlet will remove the turbo outlet allowing your turbo to flow exhaust gasses more efficiently. Is a direct bolt in for the EVO. Will work with factory exhaust as well as any exhaust that would keep the factory Turbo outlet and stock donut gasket. And is constructed of fully polished 304 stainless steel.
The O2 sensor on this is located a little further away then stock but no wire extension is required even though some people have chosen to do so.
Price is 224.99 Shipped inside the 48 states these can ship immediately
A picture explains it best
It is 2.75" at the outlet. I haven't measured the stock one but i think it is close to 2.4" I will bring mine in from home and measure it.
I think 2.75 is the biggest you can go and work with the stock donut gasket size.
No problem on the picture sorry to make you guys look at my white as hell arms but we don't see the sun to often to busy shipping parts.
I am not sure on the AMS downpipe but if the stock donut works on it then this will work.
Ben
Ben
After hearing people complain about all the bolts not fitting and people installing them without all the bolts I created a picture to assist you guys with install.
The studs are what caused the issue. Due to the huge size of these piece you have to flip one stud upside-down and relocated the other one.
hope this helps. By doing this you can use all bolts and nuts to properly secure this piece.
Originally Posted by Due to the huge size of these piece you have to flip one stud upside-down and relocated the other one.
Originally Posted by Ryu123
Flipping the stud does not work when I tried it. The stud bottoms out on the hotside and the area on the stud where its not threaded sticks out too far so the nut will not thread down far enough to secure the O2 housing to it.
It worked perfectly on my car.
If needed you would just need to cut the stud down a little to make it work.
RallySport Direct
EvoX 'For Sale' External Engine / Power
Dec 7, 2009 09:22 PM
RallySport Direct
Nov 14, 2009 10:18 AM
RallySport Direct
124
Mar 14, 2006 10:28 AM
RallySport Direct
Evo 'For Sale' Exterior Styling
Feb 23, 2006 08:28 AM
RallySport Direct
45
Nov 22, 2005 09:05 AM
