Lots of Items // In Stock // READY TO SHIP. READY TO INSTALL!!
Old Jul 6, 2006 | 06:28 PM
Gruppe-S's Avatar
SPECIFIC ITEMS, RED TAGGED TO GO!!
GRUPPE-S CARBON FIBER RADIATOR SHROUD- $99 SHIPPED!!!
Manufactured to force air thru the radiator to get optimal cooling during extreme racing conditions. Full Dry Carbon Fiber design.
GRUPPE-S CARBON FIBER VALVE AND CAMGEAR COVER - $225 SHIPPED!!!
MR BOV - $99 SHIPPED!!
Tested to hold significantly more boost than the stock BOV, at a fraction of the cost of most aftermarket valves. This BOV features all metal construction, stiffer valve spring and recirculates back to the intake so as not to throw off MAF readings, or cause any driveability issues.
Go Fast Bits Stealth FX BOV - $299 SHIPPED!!
Fully adjustable - Anywhere from 100% vent to atmosphere to 100% vent to intake.
- Easy adjusted by twisting the lower cap ring.
- Evo specific kit w/ proper mounting flange.
- Available in Black, Red, Silver, Blue.
Helix Test Pipe - $109 SHIPPED!! **$149 SHIPPED!!**
The Helix Test Pipes are the optimal system for the performance minded EVO owner.
- Piping diameter is 3 inches
- Dyno proven of 8-15 whp gain when used in conjunction with a catback system.
- Ideal fitment for Evo 8, but will fit Evo 9 with welding on of a 02 sensor flange.
Mitsubishi 10.5 Dual Port Hotside - $209 SHIPPED!! **$499 INSTALLED**
Significantly increases mid-range to top end power are seen with this addition of this turbine housing, and this is why this turbine housing is found on upgraded turbos such as the TME.
- Helix 10.5cm > Stock 9.8cm Housing
- This increased nozzle area is perfectly suited for high boost / high RPM duty.
- The larger twin-flapper setup allows for greater boost control and a reduction in boost creep.
Maxford Headers - $219 SHIPPED!! **475 INSTALLED!!**
Excellent "power for the dollar" modification as greatly reduces turbo spool time while increasing mid range torque and top end power.
- Constructed from beefy 3mm 304 Stainless steel tube with high quality TIG welds.
- Retains the true twin scroll design of the factory turbo.
Tanabe Downpipe - $249 SHIPPED!! **$315 INSTALLED!!**
The Tanabe downpipe features stainless mandrel bent piping in 70mm design.[/B]
- The downpipe clears the factory lower arm bars.
- This downpipe yields about 7-10whp and is better suited for mildly modified Evo's.
HKS 3037S Turbo Kit - $4,999 SHIPPED!! **$5,999 INSTALLED!!**
PLEASE PM FOR FREE PERFORMANCE ITEM SPECIAL WITH THIS TURBO ORDER
Complete kit designed/sized for maximum HP w/ minimal increase in lag.[/B]
- 500+ HP capable w/ proper Engine Management and Tuning.
- Ultra-efficient custom Garrett based ball-bearing turbo - Exclusive to HKS.
- Includes all hardware to provide a complete installation.
JDM TME 6.5 Titanium Turbo 300+ HP - $799 w/ Free Shipping!! **$1,125 INSTALLED!!**
The Mitsubishi RS T.M.E turbocharger uses a titanium aluminize shaft to reduce the shaft weight by an amazing 30%![/B]
- 300+ HP capable w/ proper Engine Management and Tuning.
- Larger 10.5cm turbine housing.
- Direct Mitsubishi made replacement, that gives way more power!!
Helix 720cc Injectors - $365 Shipped!! $449 Shipped w/ Walbro FP!!
Injector on-time, spray pattern, and flow rate are all properly matched for maximum power and reliability.
- Flow rate capable of supporting 500+ HP applications
- Manufactured by famous Japanese OEM manufacture
- Excellent build quality compared to cheaper Lucus made injectors
- Bolt-on replacement w/ no modifications required
Helix V2 Cam Gears - $149 SHIPPED!! **$279 INSTALLED!!**
$649 SHIPPED w/ HELIX 272 CAMS **$969 INSTALLED!!**
$849 SHIPPED w/ HKS 272 CAMS **$1,169 INSTALLED!!**
Helix Power is pleased to announce the Version 2 release of its 5-bolt cam gears for the Mitsubishi Lancer Evolution VIII (4G63).[/B]
Differences between V1 & V2:
- New Manufacture!
- Lighter then the original!!
- Direct drop in to stock cam gear covers without modification!!!
Helix 272/272 Camshaft Set - $399 SHIPPED!! **$699 INSTALLED!!**
Unique hollow-core billet camshafts designed for maximum power gains with unmatched streetability.
- Hollow-cored design reduces rotational mass for increased "revability."
- 272 degree duration w/ 10.8mm lift intake & 10.2mm lift exhaust.
- Perfect match w/ ultra-light Helix cam gears.
HKS 264, 272 or 280 Camshaft Set - $599 SHIPPED!! **$899 INSTALLED!!**
HKS 272/272 Camshaft Set *Slightly Used* - $499 SHIPPED!! **$799 INSTALLED!!**
The camshafts are direct replacements and are designed to be compatible with the factory followers and valve springs.
- HKS also offers high performance valve spring sets for limited applications that can benefit from stiffer springs when using Larger profile HKS camshafts.
- These camshafts can provide additional 20+ whp on turbocharged applications.
Exedy Stage 2 Organic Clutch Kit - $499 SHIPPED!! **$1,165 INSTALLED!!**
$599 Shipped w/ Gruppe-S Flywheel!! **$1,275 INSTALLED!!**
Complete clutch replacement kit w/ upgraded pressure plate and disc.
- 44% torque capacity increase - Handles cars making up to 400 HP.
- Includes new throwout bearing and alignment tool.
ACT HD Street Disc Clutch Kit - $475 SHIPPED!! **$1,150 INSTALLED!!**
$625 Shipped w/ Gruppe-S Flywheel!! **$1,250 INSTALLED!!**
- 38% torque capacity increase - Handles cars making up to 400 HP.
Gruppe-S Lightweight Flywheel - $199 SHIPPED!!
Our own stock replacement flywheel designed to work with any stock replacement clutch.
- Ultra-strong forged steel construction more durable than aluminum units.
- 10.5 lbs weight increases throttle response without sacrificing driveability.
Exedy Multiplate Clutch Kits
Exedy Hyper Single Clutch/Flywheel Kit - $1,285 SHIPPED!! **$1,899 INSTALLED!!**
Exedy Twin Plate Clutch/Flywheel Kit - PM FOR PRICING **$2,299 INSTALLED!!**
All Exedy multi-plate clutches come with a lightweight, chrome moly steel flywheel and the famous purple anodized forged aluminum clutch cover.
- Most Durable Pressure Plate, rebuildable with rebuild kit.
CA RESIDENTS PLEASE ADD 7.25% TAX/8.75% FOR ALAMEDA
SEND PAYPAL PAYMENTS TO sales@gruppe-s.com
Thanks,
Mark
Tel: 510 783 5300
Mark@gruppe-s.com
Paypal: sales@gruppe-s.com
[/B]
Old Jul 11, 2006 | 10:15 AM
Gruppe-S's Avatar
Bump for Awesome Install Specials!!
