Tilton Cerametallic Twins IN STOCK!
Two backordered Tilton twindisc cerametallic twins rated to 600bhp just came in this evening. First come first served while in stock. PM for pricing!
The flywheel included in the packages has been engineered to have a compromised weight/inertia that provides increased performance (faster engine acceleration) and good drivability (reduced bogging). Also included with each clutch package is a hydraulic release bearing (HRB) that mounts inside the bellhousing and replaces the stock slave cylinder/fork arm release bearing mechanism. This HRB provides quick shifting, low pedal effort and self-adjusts for clutch wear.
Tilton’s Full Twin Cerametallic clutch packages were engineered for track or extreme street applications. The cerametallic discs can withstand increased abuse when compared to organic-type discs, such as harder shifting typically seen at open track days and higher temperatures generated when the clutch is slipped excessively to get a good launch.
Features: 7.25inch 2-plate cerametallic clutch. Rated torque capacity: 740 lb-ft* Billet 4140 steel flywheel with integral-cut ring gear. Hydraulic release bearing assembly Aircraft-quality hardware Total Weight 19.1 lbs
Somehow I missed a Tilton memo and wanted to set the record straight.
All Tiltons manufactured AFTER June of 2006 have the following specs:
TILTON - Twin Organic/Cerametallic is RATED to 620 ft-lbs btq.
TILTON - Twin Organic/Cerametallic is RATED to 740 ft-lbs btq.
STM Tuned
Jan 23, 2015 12:17 PM
BigValley
Evo 'For Sale' Engine Internals and Drivetrain
45
Jul 17, 2009 03:17 PM
Jack @ EvoStore
Oct 2, 2006 07:33 AM
TTP Engineering
39
Dec 12, 2005 10:06 PM
