TTP-Engineering February Kickoff Featured Products!
Power Division High Performance Billet Camshafts.
Engineered to offer the absolute best performance and maintain close to stock drivability characteristics. Power Division has stepped into the market with top quality Billet Cores that will perform with or outperform other camshafts on the market. With the wide array of profiles there is a combination to fit your needs. From an Evolution 8 with basic bolt-ons to fully built engines and large aftermarket turbo's Power Division offers the setup to suit your needs. All the camshafts provide power across the RPM band and can support extreme race engine conditions due to their superb quality. Why run the others, when you can run the BEST!!!
Key features:
Redesigned profile for smoother valve motion, can be used with stock valve springs (V2 Upgrade)
Broadest power increase of any Evo cam on the market
Industry leading tolerances .0001
1 year warranty
Micro polished lobes for reduced friction and faster brake in
OEM chill casting core technology
Idle is near stock
Can be used with Stock Valve Springs
$SPECIAL $469 SHIPPED! PRICING 2 SETS IN-STOCK, Ready to ship!
What is the construction on your test pipe with the built in resonator? Is it a baffled design or straight thru. I am simply trying to eliminate the raspy tone I acquired after going the big turbo route...
Its straight through with perforated holes along the walls that reduce the raspy and tinny sound a straight pipe non-resonated gives you.
3. Forge UNOS Manual Boost Controllers in POLISHED ALUMINUM or ANODIZED BLACK
The Forge UNOS boost Controller is CNC machined to aircraft specifications and incorporates a ratchet type top adjuster that will allow for the positive and precise adjustment that your driving style demands. The controller can be dash or engine bay mounted to suit your preference.
This product is a universal component, and as such, no vehicle-specific fitting instructions can be provided.
This product is designed and built with the intent of increasing the boost output of any forced induction system. We cannot guarantee compatibility with all applications, nor the ability to increase the boost output beyond a level that is within the parameters set by the engine-management-system of the given vehicle at the time of installation, whether that system is factory or aftermarket.
Forge Motorsport nor any of it’s Authorized Distributors can assume any responsibility for any adverse effects resulting from the installation and tuning of this product onto a vehicle whose engine-management-system, whether factory or aftermarket, is not capable of allowing for the desired level of adjustment.
$85 SHIPPED!
Back on topis...great deals!
