TTP-Engineering February Kickoff Featured Products!
Old Feb 26, 2007 | 10:49 AM
  #46
TTP Engineering's Avatar
Off a long backorder I have a shipment that came in.
This bushing is made from a 80 durometer polyurethane where the OEM rubber bushing is rated at about a 45-50 durometer rubber material (much softer) and the Powerflex kit comes supplied with a specific stainless steel sleeve and a packet of copper grease/anti-seize.
It is a direct replacement for the soft OEM front mount bushing and fits with absolutely no modification. Installation takes about 20 minutes. This stiff mount will improve starting from a stop, braking, and will improve shifting as the motor will no longer roll around in the engine bay.
$54 - FREE SHIPPING!
Side mount and transmission mount will improve turning and solid feel of the car without engine roll from the stock soft mounts.
ADD the two side mounts for $120 - FREE SHIPPING!
__________________________________________________ ___________
OK, OK.... a few off backorder front lower and side motor mounts has just arrived.
First come, first serve basis.
They were backordered for 3-4 months prior to this, so if you want them, here is your chance.
Old Feb 26, 2007 | 11:50 AM
  #47
Evoryder's Avatar
PM price on GSC S1 cams evo 8 to 33186 Mr. Scott
Old Feb 27, 2007 | 06:45 PM
  #48
o-townFLA's Avatar
Finnaly got my TBE and Forge boost controler all installed and super stoked...!
Just saving funds now for an reflash($200 bucks-ouch!), have to mail out ECU... no laptop, so no E-flash
TTP has won another customer.....
Old Feb 28, 2007 | 08:33 AM
  #49
Now let's get you tuned...
Old Feb 28, 2007 | 01:31 PM
  #50
koffebean00's Avatar
Recieved my TTP resonated test pipe and Megan exhaust today. I installed it along with a Buschur downpipe. It sounds great! I've been looking for reasons to leave the house so I can hear/drive my car.
Thanks again!
Old Feb 28, 2007 | 10:44 PM
  #51
srt2evo9's Avatar
so your sure theres no more of the forge divertor valves you may have over looked
Old Feb 28, 2007 | 10:51 PM
  #52
EvoDan2004's Avatar
how much is the gates surpinteen belt added with the gates timing belt kit??
Old Mar 1, 2007 | 07:22 AM
  #53
We were going to put a package together for them all, but did not see a matching quality blue belt to the timing and bal shaft belt.
All I have seen is OEM-like black. If there is still an interest, we can pursue these.
Old Mar 1, 2007 | 08:03 AM
  #54
EvoDan2004's Avatar
o darn is not blue. ok well is it still a gates belt? is it still stronger? or is there others lke power enterprize out there?? i would understand it not being a package deal because its not te same brand but let me kow eather way when i do this that belt has to come off so im replacing it anyway. thanks bro
Old Mar 1, 2007 | 09:32 AM
  #55
Gates belt kits are back in stock!
Injen Intake kits with lower and upper piping back in stock!
ACT XTSS Extreme Single Disc ONLY a small quantity of backordered units from a December order just arrived!
Rare 6-puck sprung hub cerametallic HD single disc high torque, no lockout ACT clutch - ONLY 3 available!
First come, first to receive.
Old Mar 1, 2007 | 09:57 AM
  #56
EvoDan2004's Avatar
Old Mar 5, 2007 | 07:02 AM
  #57
Not currently offering the Gates accessory belt, but timing and balance shaft belts.
Still have some front and side POWERFLEX motor mounts in stock, ready to ship.
Old Mar 10, 2007 | 09:58 PM
  #58
Pure EvoIX's Avatar
1) will the TTP Downpipe and Resonated Test Pipe fit with the AMS 3" Exhaust on a IX?
2) Does the Resonated Test Pipe throw a CEL? If yes, does it need a CEL fix.
3) one last question...can the stock cat be swapped for the test pipe?
-questions are critical in order for me to pull the trigger.
Old Mar 11, 2007 | 10:38 AM
  #59
ACT clutches in stock from 3 month backorder.
HDSS available! PM for pricing-
XTSS available! PM for pricing-
Special TTP track model available for improved shifting and tq holding! PM for pricing-
IMPORTIMAGE
Lancer Vendor Classifieds
337
Nov 16, 2012 12:05 PM
TTP Engineering
Evo X Dyno Results
31
Oct 26, 2009 02:27 PM
TTP Engineering
Aug 8, 2009 12:03 AM
TTP Engineering
Jun 14, 2008 08:55 AM
TTP Engineering
Jul 17, 2006 10:11 PM
