Helix TBE $775! Greddy TBE $975! Tanabe TBE $999! Helix Cam Pack $399! AEROSYNC ESD
Hey guys worked out some amazing deals for you!!
HELIX HELIX HELIX!!!
HELIX SUPER POWER PACKAGE #2+
-Helix 3” Cat-Back Exhaust
-Helix 3” Test Pipe
-DC 3” Down Pipe
-Helix O2 Housing
-Helix 272 Hollow Core Camshafts
-Helix UL Cam Gears
Normal Price: $1645.00
SALE PRICE: $1149.00 SHIPPED!!
GRUPPE-S POWER PACKAGE #2
-ADD 75WHP / 70TQ!!
-Helix Ultra-Light 272 Camshafts
-Helix Ultra-Light Adjustable Cam Gears
-Walbro Fuel Pump
-For EVO VIII only (IX owners please see our IX combos)
$475 SHIPPED!!!
CAMS AND GEARS ONLY? $399.00 SHIPPED!!
TURBO BACK SPECIALS!!
HELIX/DC TURBO BACK EXHAUST!!
-Helix 3” Test Pipe
-DC 3” Down Pipe
-Helix O2 Housing
-30+ HP GAINS!
Normal Price: $997.00
SALE PRICE: $775.00 SHIPPED!!
GREDDY/HELIX TURBO BACK EXHAUST!!
-Greddy Evo2 Cat-Back Exhaust
-Helix 3” Test Pipe
-Helix O2 Housing
-DC 3” Down Pipe
Normal Price: $1083.00
SALE PRICE: $975.00 SHIPPED!!
TANABE CONCEPT G BLUE TBE
-Tanabe Concept G Blue
-Helix O2 Housing
Normal Price: $1048.00
SALES PRICE: $999.00 SHIPPED!!
TANABE/HELIX TURBO BACK EXHAUST!!
-Tanabe Medallion Touring
-DC 3” Down Pipe
-Helix 3” Test Pipe
-Helix O2 Housing
Normal Price: $1107.00
AEROSYNC ENGINE SHOCK DAMPER!!
Gruppe-S is pleased to release of the Gruppe-S / Aerosync Engine Shock Damper. The ESD is designed to reduce engine vibration and movement for the Lancer Evolution VIII / IX. By reducing vibration an improvement in transmission feel, shift response and a reduction in driveline / motor-mount fatigue is achieved.
The Gruppe-S ESD is an improvement over the now discontinued Stillway ™ Engine dampers. The Gruppe-S shock damper employs the use of superior heat-treated springs which resists spring fatigue and wear. Furthermore the Gruppe-S shock dampers now employ full investment cast SS304 brackets which both eliminate cracking issues associated with welded brackets and allow a lighter overall product without compromising strength.
$99 SHIPPED!! (Please specify color)
EVO IX FULL CAM PACKAGE
-Cosworth 272 Cams (pair)
-Helix 720cc Injectors
-Good for 310whp with proper mods & tuning
$899 Shipped!!
*Fuel Pump & valvetrain recommended
HELIX 1000cc Injectors
-1000cc worth of flow
-Good for over 750HP
-Made in Japan by Denso
$539 Shipped!!
AEM EMS Stand-Alone EMS for the EVO IX (MIVEC)
-Full Standalone enginemanagement
-Compatible with MIVEC cars (EVO IX)
-Includes 3-bar Map Sensor & Temp Sensor
$CALL OR PM!!!!!
TUNING TOOL COMBO!
-PLX M250 WB02 with 52mm AFR gauge
-OpenECU Access Cable
-Compatible with EVO VIII & IX
$399 Shipped!!
OPEN ECU COMBO
-Open ECU Access Cable
-Gruppe-S light weight crank pulley (black or silver available)
-Full access to all ECU parameters
-Reduce engine rotational mass by 3lbs
$115 Shipped!!
Thanks,
Travis
Gruppe-S
510-783-5300
510-783-4300 fax
-Helix 3” Test Pipe
-DC 3” Down Pipe
-Helix O2 Housing
-Helix UL Cam Gears
-ADD 75WHP / 70TQ!!
-Walbro Fuel Pump
$475 SHIPPED!!!
-Helix 3” Test Pipe
-DC 3” Down Pipe
-Helix O2 Housing
-30+ HP GAINS!
-Helix 3” Test Pipe
-Helix O2 Housing
-DC 3” Down Pipe
-Helix O2 Housing
-DC 3” Down Pipe
-Helix 3” Test Pipe
-Helix O2 Housing
$899 Shipped!!
$539 Shipped!!
$CALL OR PM!!!!!
TUNING TOOL COMBO!
$399 Shipped!!
OPEN ECU COMBO
$115 Shipped!!
Thanks,
Travis
Gruppe-S
510-783-5300
510-783-4300 fax
just curious... do you have a "before and after" of your crank pulley only?
yall seem to be pushin them awfull hard if ya posted a dyno alot more people would be less sceptical, jus my .02
more so i'm curious
also you guys use a mustang dyno if i remember right so even a 4-5 whp increase would be worth noting
more so i'm curious
Bump for a great vendor and a absolutely AWESOME exhaust.
Short video of my Helix TBE w/ HFC here: http://www.youtube.com/watch?v=xIfa9OBFIHo
nooshefx - PM Sent!
matyb - Sorry no dyno charts of just the crank pulley alone. Ill let you know if we do one.
Tachyonzero - The software can be found at www.openecu.org. Check it out its free so all you need is the cable. thanks!
ShamelessCookie - Thanks for the bump! Great video!
-Travis
-Travis
Sorry but currently we are not carrying any high flow cats at this time. Give me a call at (510)783-5300 and ask for me, Travis. Ill work something out for you. Thanks!
-Travis
-Travis
Why do you list the DC DP and the Helix TP in a combo together when the DC DP eliminates the need of a test pipe separately as it already runs longer to the back.. meeting with the cat back..
Actually there is a superceeding model to the DC DP that replaces the cat. The new model is the down pipe only and does not include the cat delete portion. Let me know if you would like to place an order. Thanks!
-Travis
-Travis
