Sun Auto Hyper Force, Grounding Kits, and Ignition Blade in stock at 201!!
We are proud to announce that we are Sun Automobile's newest authorized dealer! All of these products are in stock and ready to ship out today (May 8th)!!!
___________________________________
Hyper Ground System
Hyper Ground System
Originally Posted by Sun Automobile USA
The new Hyper Ground System is the safe and reliable generation tuning system that provides a low resistance ground path. A better ground gives more Torque,better Mileage, better Response, and better Starting Ability.
Hyper Ground System is the best performing grounding system available!
Sun Auto is the only company authorized to provide high performance grounding system as OEM optional equipment.
This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation. In addition "Hyper Ground System" cables have 10 times less impedance than factory ground systems which provides immaculate conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential.
The "Hyper Ground System" uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles.
Price:$144 shipped
Hyper Force System
Hyper Force System
Sun Hyper Force System is new high-efficiency ignition tuning and strengthening system by Sun Automobile. Hyper Force System focuses on direct ignition engines and is available in 4 and 6 cylinder versions.
A normal ignition coil inherently generates back electromotive force (back EMF) during operation. This back EMF negatively affects the ignition device inside the coil, decreases plug voltage, and negatively affects plug efficiency. With this problem, voltage not only becomes unstable but also produces ignition time lag in the next ignition cycle. HYPER FORCE SYSTEM works by absorbing all back EMF, which aids to improve plug voltage and promote complete combustion by producing 100% coil efficiency. Furthermore, HYPER FORCE SYSTEM eliminates any ignition performance loss due to decreased electrical current under heavy throttle. Since ignition efficiency over the entire rev range improves, available torque and acceleration response improves; this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emissions.
What results? Increased Engine Response, Improved Fuel Efficiency, Increased Horse Power and Torque, Reliable ignition spark throughout the entire rev range, and Reduced emissions / stabilized idling
Price:$350 shipped (Evo-specific harness included!)
Spark Plug Cover
Spark Plug Cover
Introducing an all new ignition strengthening product born from the Hyper Ground System. It eliminates negative ions circulating throughout the ignition coils and cylinder head, therefore, providing the lowest possible resistance enabling the ignition system to reach maximum potential.
NOTE: When installing in conjunction with Hyper Force System, you can expect an even better result!
Price:$162 shipped
Thanks a ton
Your package will be shipping out first thing tomorrow! I'll PM over a tracking number tomorrow as well... I'll let you know once the Hyper Voltage System comes in too!
I should clarify... I made a mistake. The Blue is the only color available for the Evo-specific grounding kit. Sun offers many colors for the universal set up. Sorry about the confusion!
201Motorsports
38
Dec 6, 2009 11:20 PM
201Motorsports
29
Apr 17, 2009 05:25 PM
201Motorsports
28
Jan 10, 2009 05:19 AM
201Motorsports
15
Oct 24, 2007 07:01 AM
201Motorsports
Aug 31, 2007 12:04 PM
