___Methanol/Water Injection Kits | THMotorsports___
Old Jan 17, 2008 | 02:25 PM
THmotorsports's Avatar
Labonte Motorsports Methanol/Water Injection Kits
Labonte Motorsports is the creator of the "Sn0w" kit that many of you see. They have been producing these for the company and we are now selling their products exclusively as the midwest master distributor. The products are the utmost best quality and we cant stress how cost effective this solution is.
Kit Price: $369 shipped (Includes ISG-10 Kit, V25-D Controller)
Quantity Available: 24
Methanol/water Injection:
Through the use of methanol, found in windshield washer fluid (Super cost effective), spraying it into your intake charge decreases intake temps and decreases chance of detonation, and thus you can run more boost. It is like running 110 octane. With the methanol, you guys can create custom maps for around 110 octance levels and get some serious power, without driving or buying expensive 110. The kits are simple, and run based upon duty cycle of the engine. You can run it at your own settings or have it run through something like the AEM EMS.
Again to re-cap:
- prevents detonation and pre-detonation
- uses methanol aka "windshield washer fluid" which can be bought anywhere and for $1-2 for a 2 galloner
- Lets you run more boost
- Lower intake charge
- Similar to running 110 octane based on saftey levels
- Runs automatically based upon duty cycle and boost levels
- Can be ran through AEM EMS and others constantly with custom controls
What the kit includes:
ISG-10
Features:
• Alcohol safe 150psi Pump
• 2qt Fluid Tank
• High Atomization Injection Nozzles
• 15 feet high pressure hose
• Complete Install Instructions
• Easy Installation and Setup
• 1 Year Warranty
VC-25D - 25psi Boost/MAF Activated Controller Mitsubishi
Features:
• Make more Power and lower EGTs with Variable Control
• Controls Injection Pressure as a function of Boost and MAF
• Fully Integrated MAP Sensor 0 to 30 psi
• Potted Electronics and Rugged Design for Under Hood Applications
• 1.5% Maximum Error over 0° to 85°C
• Easy Adjustment and Setup
• Ideal for Mitsubishi, Dodge and some Chrysler Turbo Engines
• 1 Year Warranty
These two are the complete kit for the EVO ran off the MAF/4bar.
Monitoring:
If you need to monitor all parameters. The display is for you!
VCS3G - 3D Injection Controller w/Dash Display
The VCS3G from Labonte MotorSports is not just an injection controller. It is a fueling computer for water-methanol injection systems. The advanced control algorithm was developed through rigorous engineering and dyno testing to deliver precise control of injection. Delivering the right quantity at the right time leads to maximum horse power and detonation control from an injection system.
Features:
• User friendly-system "tunes" itself. Simply enter pump type, boost start point, nozzle size, and approx HP - and the correct injection quantity is configured from the units 3D injection algorithm
• True 3D injection control based on engine fueling and boost pressure for maximum power and the most accurate injection at all times
• Injection Fail Safe input displays actual injection qty on screen and warns if injection goes below set-point for enhanced reliability
• Adjustable on-the-fly for additional fine tuning (+ or - of the injection map) from the drivers seat
• Internal MAP Sensor reads 0-30psi
• Fluid Level switch input and warning indicator/beeper
• Advance LCD and touch screen control panel allows easy setup, tuning and monitoring of system, all on the fly in real-time
• Displays Injector Duty Cycle, Boost (psi/bar), % water-methanol injectoin, warning indicators for low-flow or low fluid level (with optional upgrades)
• Extensive System Diagnostics for error free usability
• Peak & Hold displays Max Boost, IDC and Injection
• Additional 12V output signal for running nitrous, etc.
• Includes: Dash Display Module w/mounting bracket, engine bay injection controller, Laptop cable to update flash memory, wire harnesses for complete install.
• Designed to operate on Fuel Injected gasoline engines with Forced Induction (Turbo or Supercharger)
• 1 Year Warranty
The install:
Old Jan 22, 2008 | 09:21 AM
bump
Old Jan 29, 2008 | 05:00 PM
Added some, more details coming tomorrow and clean up
Old Jan 30, 2008 | 07:03 AM
Bump!
Old Jan 31, 2008 | 09:48 AM
bump! Edit coming today
Old Feb 1, 2008 | 02:07 PM
Bumpin it
Old Feb 1, 2008 | 02:19 PM
boostGotMeLaid's Avatar
pm me price shipped
Old Feb 3, 2008 | 04:21 AM
EvoKnievo's Avatar
pm shipped to 95476.
Old Feb 4, 2008 | 09:10 AM
Pm'd you all
Old Feb 5, 2008 | 09:41 AM
Pm's sent again. Wow, that was a lot of em
Old Feb 7, 2008 | 12:54 PM
Pm's sent
Old Feb 11, 2008 | 09:39 AM
Thanks for the orders.
Old Feb 13, 2008 | 02:00 PM
Pm'd. prices are lower than SNOW's kits, and they are identical and made by labonte .
Old Feb 14, 2008 | 08:42 AM
3 sets sold so far to you evo guys, keep em coming!
Old Feb 15, 2008 | 06:38 PM
justboosted02's Avatar
could you explain the failsafe system in more detail? does it allow you to cut boost though a solenoid if a low flow situation is present?
