PERRIN/PWR/INJEN COOLING THREAD - Just in time for SUMMER!
PERRIN FRONT MOUNT INTERCOOLER
Once simple look at thephotos above and it is easy to see the VAST difference in shear size ofthe PERRIN Front Mount Intercooler over the OEM one! This is certainlyan ideal case of size DOES matter.
Turbocharged engines rely on the compression of air to make boost. Not only does this process raisethe temperature of the air, but the unit doing it (the turbo) is also extremely hot. While the motor benefits from the increased pressure,far more HP can be gained by cooling that air down to increase thedensity. The factory did a great job of placement of front, but theyare limited by budget when choosing the core material and size. This iswhere PERRIN is allowed to excel!
All PERRIN intercoolers are made right here in the USA using similar core designs used on military aircraft, large diesel applications, ships and the like. Divorcing ourselves from the Chinese sourced cores has allowed us to make more HP, have better quality, yet we have been able to keep costs down tostill offer you a superior product at a more than reasonable cost. Weuse a bar and plate design to the core material. This gives us moresurface area per cubic inch that tube and fin, along with less pressuredrop across the core. Don't forget the cast aluminum endtanks. Reduceweight and increase flow by eliminating restriction. Additionally, in our quality control area, each core is tested at 120 psi, for ANY leaks. If the core leaks in anyway, it is immediately rejected,repaired and re-inspected. When you buy from PERRIN you can be assuredthat your core is of the highest quality.
So what all does thistechnology and quality mean to you? Well PERRIN offers the largestcore, the least pressure drop, the most HP gain over stock (someclients can see more than 30 WHP gain!), supports up to 1000HP, and allof this can be installed at home with simple hand tools. This even fitscompletely behind the OEM bumper skin! No cutting or hacking isrequired.
Backed by the PERRIN Warranty, customer service andtech support this is a real value at this price! Questions? Need asound clip? Just let us know. Happy to help via e-mail, AIM, fax orphone!
REGULAR FMIC - MSRP: $759.99, Our Price: $649 Shipped!
STEALTH FMIC - MSRP: $799.99, Our Price: $729 Shipped!
Injen Aluminum Intake System w/ Full Intercooler Piping: EVO
With an amazing gain of up to 22hp, this kit features a cast multi-stage tuned mid section for volumized airflow throughout the entire power band. Combined with the upper intercooler piping (included), and now the lower IC Pipe as well, the system eliminates hose expansion to increase throttle body response going into boost. Dyno proven performance, not hype! This system will work with the factory Front mount on the Evo or with almost any of the aftermarket units.
MSRP: $550.80, Our Price: $409 Shipped!
Injen Intercooler Pipe Kit Mitsubishi EVO VIII/MR 03-06
The all new Intercooler Piping Kit will accommodate your stock intercooler and give it the added dress up your engine needs. This three piece system easily bolts on to your 2003-2005 EVO VIII and 2005-2006 MR without any modifications and includeds heavy duty T-bolt type clamps.
KEY FEATURES:
- Three Piece design
- T-Bolt type Clamps
- Accommodates Stock Intercooler core
- Completely Bolt On
Note: Will NOT work with Factory Air Box
MSRP: $475.50, Our Price: $369 Shipped!
Koyo high performance radiator - 03+ EVO
# Fully polished to a mirror finish
# Provide 20% to 30% more cooling than standard radiators
# Handles high revving, high performance motors
# Perfect for Turbo Charged, Super Charged & Nitros Oxide equipped engines
# Made from aircraft quality aluminum and Heli-arc welded, cores are NOCOLOK-brazed
# Koyo Radiator is on the cutting edge of technology and design with Japan's largest automobile manufacture
# Custom built OEM fit - All Koyo Radiator cores and tanks are specifically designed and built for each application. No universal fit parts are used.This ensures proper fit, just like your original equipment!
MSRP: $499, Our Price: $425 Shipped!
PWR Aluminum Radiator: 03+ EVO
PWR alloy radiator is a direct bolt in. Full aluminum end tanks and core. This enables maximum cooling and power efficiency. Utilizing all stock mounts, there is no modification necessary. Add this nice improvement for additional horsepower and cooling. Its a well known fact that the 4G63 motor runs really warm, especially when running more HP and higher boost. This stock fit radiator is 100% Tig- welded Aluminum and uses a furnace brazed core giving 30-35% more efficient cooling!
PWR 40MM - Our Price: $629 Shipped!
PWR 57MM - Our Price: $649 Shipped!
PWR Front Mount Intercooler: 03+ EVO
PWR Intercoolers are manufactured using the highly efficient and light weight tube cores are individually made by hand and the tubes cut to the required length. The EVO intercooler uses the OEM piping so there is no need for aftermarket piping but is useable with most aftermaket pipe kits.
The PWR measures in at : 23.5"x12" x3" for a total 846 cubic inches.
The intercooler core is rated for a whopping 1320cfm flow capacity and has a 282 cubic inch surface area with less then 1psi air pressure drop increasing power output significantly! PWR's extruded tubes and rounded on the ambient air side to allow for smoother cooling air flow for additional efficiency.
Our Price: $899 Shipped!
Samco Intercooler Hoses - 03+ EVO
Time to retire your factory Intercooler hoses and radiator hoses!!!! Did you think these will last you forever??
Samco Hoses are 4x more durable compared to OEM hoses. Built to handle extreme heat and cold other hoses cannot. Specially manufactured to insure OEM fitment while also having the ability to hold extreme PSi standard rubber hoses cannot.
EVO VIII - MSRP: $299, Our Price: $275 Shipped! (Available Color: Black, Blue, Red, Yellow)
EVP IX - MSRP: $334.86, Our Price: $295 Shipped! (Available Color: Black, Blue, Red, Yellow)
Samco Hose Radiator Hose Kit for EVO VIII and IX
EVO VIII - $109, Our Price: $99 shipped!
EVO IX - $138.58, Our Price: $129 Shipped!
Please give us a call to order!!
ALL PARTS ARE IN STOCK AND READY TO SHIP!!
Thank You!
KEY FEATURES:
Thank You!
Speed Element
EvoX 'For Sale' External Engine / Power
May 25, 2010 05:45 PM
Speed Element
12
Oct 7, 2008 10:53 AM
Speed Element
Evo 'For Sale' Miscellaneous
Mar 19, 2008 02:19 PM
Speed Element
Mar 18, 2008 06:28 PM
Speed Element
Feb 13, 2008 02:34 PM
