Synapse Engineering Universal Synchronic Blow-Off Valve/ BOV adapters available
Old May 25, 2010 | 03:20 PM
  #271
Chris@nolimitmotors's Avatar
Originally Posted by mountainturbo
Looking at maybe buying one of these bad boys soon. I'm planning on getting the ETS UICP, should I just have them put the stock DV flange on it?
Does the kit you sell for the evo-specific model include the recirc stuff?
Hey yes the kit i sell comes with a evo specific flange that would be the same as the stock one and a recirc fitting also
Old May 25, 2010 | 06:47 PM
  #272
mountainturbo's Avatar
Pm sent, I want one
Old May 28, 2010 | 01:52 PM
  #273
Old Jun 1, 2010 | 12:58 PM
  #274
Old Jun 15, 2010 | 11:18 AM
  #275
Old Jun 16, 2010 | 11:53 AM
  #276
Old Jun 21, 2010 | 02:05 PM
  #277
Old Jun 22, 2010 | 01:03 PM
  #278
Old Jun 25, 2010 | 02:08 PM
  #279
Old Jun 28, 2010 | 04:06 PM
  #280
Old Jun 29, 2010 | 09:17 AM
  #281
Old Jul 1, 2010 | 03:01 PM
  #282
Old Jul 2, 2010 | 02:50 PM
  #283
wiseguy9's Avatar
I'm sorry I am confused, do the synapse bov's only come with port a and b and port c blocked off now? Also which model is better the 3 port or this newer 2 port I read on other threads that synapse is now making for the evo???
Thanks, Nick
Old Jul 7, 2010 | 01:18 PM
  #284
The newer ones have port C internally built in, the older ones have to have a vacuum line ran to it. Either one will work the same.
Old Jul 10, 2010 | 11:51 AM
  #285
Synapse's Avatar
Chris- I'm posting this straight to your thread so you can reference people back to it later.
Synapse Engineering would like to announce the latest major revision of the Synchronic SB001 blow-off valve. Over the last couple of years we have been integrating some small changes in the BOV design to improve ease of installation and durability. However, one thing has remained unchanged, the design of the base unit of actuation! The geometries & mathematical ratios have stayed the same from the very first prototype. We want to thank all of the early adopters that have given the product its first shot, even when there was only an M3 set screw & 3 brass ports to plumb. We definitely listened and made sure to integrate all of the community's feedback on the latest revision.
Improvements to the design are the following:
(1) M4 mounting bolts- The mounting bolts have now been changed over from M4 set screws to M4 bolts to give users the ability to apply more force when tightening down the BOV on mounting flanges.
(2) Elimination of port C on the side of the BOV- This port is now internally ported on the design and is the hallmark of the latest revision. Performance of the BOV & it's ~17 millisecond initial response time remain unchanged. The original design with an external port C was made public in case there would be the occasional application that required the boost-only source to be plumbed before the intercooler to make use of the pressure difference that may (or may not) exist before and after the intercooler. We have always had our own units internally ported for simplicity and have rigorously tested & validated this change for over 3 years. We will still have the original design in limited quantities and available only for special orders and industrial applications. We believe that the benefits in having one less connection to plumb (or fail) far outweighed the 1% of users out there that needed the externally ported design.
(3) Change to 1/8th NPT threaded vacuum ports- This design change has eliminated the use of the small M4 brass fittings. Although the initial design was compact and very light weight, we received enough feedback that prompted the change. We want to show that we do, in fact, listen to customer feedback, take it very seriously, and will only make a change after significant testing. With this change, you will no longer be able to over tighten and break brass fittings. You can also use our boost-connect fittings, which includes a 90 degree fitting for use in very tight installations. You should also know that this new back cap design is backwards compatible with even the very first Synchronic BOV released to market. You can upgrade your Synchronic BOV to this latest back cap using kit # SB001A.KIT022.
All of the universal Synchronic BOVs & application specific kits available in the market today should include all of the improvements above.
Thank you again for your support and your patience as we work to make the product the best it can possibly be. And to all of the customers, your patronage is making an impact and funding our research into developing technologies that you can actually say you helped make happen. Thank you.
For more detailed info, read support thread here: http://synapseengineering.com/smf/index.php?topic=895.0
