Synapse Engineering Universal Synchronic Blow-Off Valve/ BOV adapters available
Old Apr 9, 2008 | 02:58 PM
Chris@nolimitmotors's Avatar
  • Innovative Piston Actuated Design Based on the Patented Synchronic Technology
  • Absolutely No Diaphragm
  • Pull-Type BOV designed to Stay Closed Under Boost
  • Detachable Re-Circulation Discharge and Interchangeable Flange
Universal Synchronic Blow-Off Valve with weld on steel flange silver cover/black body. HKS, TIAL,Greddy, and stock BOV adapters availabled also. Best BOV on the market.
$210 shipped with a Adapter flange!!!!
Old Apr 9, 2008 | 04:58 PM
hellcat's Avatar
Waiting to see how these run on other Evo's. Deff. interested though. Can't get my forge RS to act like I want it to.
Old Apr 11, 2008 | 12:01 PM
Best BOV around!!
Old Apr 12, 2008 | 05:53 PM
uterus!'s Avatar
I installed mine last weekend and the car feels much better now.
My stock 9 bov was leaking at high boost and wouldn't let me run over 25lbs. It was also surging really bad ever since I installed cams and switched to e85.
This valve has solved both those problems and the car drives so smooth.
Old Apr 13, 2008 | 03:51 PM
400AtTheWheelz's Avatar
Great BOV. The ride is sooo much smoother then the forge i had. Holds boost great to (running like 28lbs). This is the best one ive owned by far.
Old Apr 14, 2008 | 05:14 PM
hytek369's Avatar
hows it sound?
Old Apr 14, 2008 | 05:55 PM
4g63_guy's Avatar
http://www.youtube.com/watch?v=mDaYJ_2NoXE
Old Apr 14, 2008 | 06:11 PM
hytek369's Avatar
thanks for the link. the install is interesting.
Old Apr 14, 2008 | 10:39 PM
uterus!'s Avatar
Originally Posted by hytek369
hows it sound?
Like something from star wars. I feel like im driving an x-wing now.
Old Apr 21, 2008 | 01:46 PM
Old Apr 21, 2008 | 02:24 PM
jmelocik's Avatar
Bump for a great deal and a great guy!
Josh
Old Apr 21, 2008 | 03:26 PM
Thanks Josh
Old Apr 30, 2008 | 11:16 AM
Synapse's Avatar
Hey guys, I just wanted to clear up an urban myth about the Synchronic BOV since it is piston driven.
Since Synchronic BOV is a piston actuated BOV, the question has come up whether or not it needs servicing with every oil change. Or perhaps it wears out over time and stops working as well as when it is new. The piston BOVs and DVs that are out on the market today, unfortunately have generated this false impression about the Synchronic BOV.
Synchronic BOV is a little bit long in dimensions because we specifically designed around this problem. In blue is the valve and the piston is in red. As you can clearly see, the piston is located in its own chamber. The valving mechanism is an actual valve that doesn't require lubricant. Existing piston designs have the actuating piston in communication with all of the airflow. So that with each dump of the BOV, there is lubricant in the system that gets discharged with it. Synchronic BOV does not need to be re-lubed since the actuating chambers retain all of our proprietary lubricant. The lubricant does not evapaporate or fade over time.
And for those of you that may be wondering about the part of the piston that is exposed to airflow, there is a wiper in the mechanism to save lubricant and that surface gets relubed with each stroke of the piston.
Old May 1, 2008 | 10:09 AM
Boltz.'s Avatar
FCOTM Winner
Based on looking at the desing of this blowoff valve it looks (this is a generalization) like a standard blow off valve that is used backwards with a second sealed chamber for the piston and modded vacuum nipples for the reverse design.
Just by looking at the CAD photos, It looks like it would remain open under vacuum. Is there a spring in this BOV? What prevents it from opening under vac?
Old May 1, 2008 | 10:22 AM
kmcconn9's Avatar
this bov rocks! Hands down the best bov I have ever used, and I have tried them all. Most of you know my setup, but these are the bovs I have used in order from worst to best:
Greddy type s
HKS
Forge RS
Stock 1g
Crushed 1g
Dejon Tool Leak stop kit and crushed 1g
Tial
And of course the Synchronic is #1 for my uses. Best driveability, on of throttle response, no shift delay.
