The goods...
Old Apr 12, 2009 | 09:07 AM
IMPORTIMAGE's Avatar
The goods...
Haltech engine management available now!!!
New special-
1x mishimoto radiator for evo 8/9 with gates racing radiator hoses $272 shipped within the 48 states!!!
http://www.importimageracing.com/c/M...s-cooling.html
evo x parts available now!!!
Haltech evo 9 standalone- E11V2 Plug-in - EVO 9 the only available standalone to FULLY control MIVEC!! $1699 shipped
Haltech evo 8 standalone- E8 Plug-in - EVO 8 $1335 shipped!
have a jdm evo? need the wideband conversion? need haltech parts? we can create packages for you!!!
FORGE IN STOCK PARTS-
EVO 8 Wastegate Actuators- $155 shipped (10 of each available at this price)
Evo 9 Wastegate Actuators- $155 shipped
Forge UNOS Manual Boost Controllers- $83 shipped each black or polished
Forge RS recirculating or atmospheric blow off valves- $195 shipped each
Vari-Cool Trunk Mount Kit. The worlds easiest to install and most advanced progressive controller kit. The controller is attached to the tank, so is the pump. Just strap it down. Pump is assembled with fittings and checkvalve. Just run the hose to your engine bay, install your injector (taps from the outside), give the controller power and ground and a boost hose source. Other kits on the market make you mount the pump, tank, controller...this kit makes that a thing of the past.!!
http://www.importimageracing.com/c/M...ution-8-9.html
WE HAVE SO MUCH FORGE STUFF IN STOCK! Help Us get rid of it..whether its in a custom combo of your choice, or individually, and we'll help you on the best pricing anywhere!
Forge Deals-
[/B]Forge Recirculating blow off valve for 03+ Lancer Evo- 153 shipped! need a better price? send us a pm
PM for pricing! We have some in black or polished, you choose!
Forge Evo wastegate actuator- PM for Pricing!
Forge Unos Manual boost controllers!!! in black and polished!
Forge In car boost controllers!!! available in black or polished
Forge hoses for evo ALL in stock!!!
FMPFF44-108 Powerflex Mitsubishi Evo 5-9 Rear Lower Engine Mount Bushing $57 shipped!
Or get the FULL motor mount kit!!
features
-FMPFF44-108 Powerflex Mitsubishi Evo 5-9 Rear Lower Engine Mount Bushing
-FMPFF44-106 Powerflex Mitsubishi Evo 5-9 Front Lower Engine Mount Bushing
-FMPFF44-105 Powerflex Mitsubishi Evo 5-9 Side Engine Mount Bushings (2 units required per car
You can get it from us for- $195 shipped!
Check out our new in cockpit manual boost controller!!!!
Forge Unos Manual Boost Controller + Walbro fuel pump combo- $149 shipped!
Forge Unos Manual Boost Controller + Walbro fuel pump combo + Fuel pump install kit - $169 shipped!
Forge Unos Manual Boost Controller + Forge evo recirculating blow off valve +
Walbro fuel pump combo- $288 shipped!
Forge Unos Manual Boost Controller + Forge evo recirculating blow off valve + Walbro fuel pump combo + install kit - $308 shipped!
Forge Unos Manual boost controller + Forge evo recirculating blow off valve combo- $219 shipped!
Forge UNOS manual boost controller + Forge RS blow off valve combo- $263 shipped!
(we have all other forge parts available send pm! tanks, seperators etc)
And the Import Image Racing in car MBC is available as well! Why pay $180+ dollars for the hallman when you can get our in car MBC for less!
Wore out a clutch disc or need a replacement part for your act or exedy setup? send us a PM and we'll hook you up with the parts you need for a great price!
WE NOW HAVE SPEC, RPS, AND CLUTCHMASTERS clutches!!! pm for best pricing!!!!
(all of these fit evo 8 and 9's)
Exedy Stage 1 Clutch Evo 8 evolution-$509.99 SHIPPED
handles 44% more tq then stock
Exedy Stage 2 Cerametallic Clutch Evo 8-$667.78 shipped!
Handles 88% more tq then stock!!!
[/B]
All EXEDY AND ACT CLUTCHES/FLYWHEELS AVAILABLE...LOWEST PRICING is here!!! Send us a PM
ACT Stage 1 Clutch for EVO 8+9-$586 shipped!!!Holds 497 ft.lbs!
ACT Streetlite flywheel- $319.99 shipped!
ACT Prolite flywheel- $349.23 shipped!
Exedy stage 1 + ACT streetlite flywheel Combo- 779.99 shipped!
Exedy stage 1 + ACT prolite flywheel Combo- 809.99 shipped!
Limited time only-
ACT Stage 1 Clutch + ACT streetlite flywheel Combo- $897.99 Shipped!!!!!
ACT Stage 1 Clutch + ACT prolite flywheel Combo- $915.99 Shipped
For more Coolingmist water injection kits check out
http://www.importimageracing.com/c/w...injection.html
Our best selling Water Injection kit!!!-
Coolingmist Stage II retails for $499.95. Your price $444.99 shipped!
* 2 Quart Tank
* Vari-Cool Coolingmist Controller
* Complete Kit!!!
* No Need To Specify Horsepower!
The Stage II controller kit is a fantastic value. You recieve our high pressure pump, vari-cool tuning controller, a 2.0 quart tank and everything else you need. The controller has a starting point for boost, a maximum point for boost and a tuning knob. The tuning knob gives you 10 algorithms to choose from. For example, if you set the minimum knob at 1 and the max at 30 and have the tuning knob at 1 it will give you a linear feed from 1-30 psi. The higher you change the tuning knob the more agressive the curve. Because of this, you do not need to change injectors when you gain more HP. Our software suite allows you to change the variables in the controller so you can fine tune if you wish. Software requires windows 2000, NT, 2003, or XP +. The controller has a 0-5V input also, so if you prefer to inject the water based on the 0-5 instead of the boost, you can do that also. What else can this unit do? Lets say you want to run based on both 0-5V input and Boost...You can set the 0-5V as the primary input and the boost as secondary or you can set the boost as primary input and 0-5V as secondary. You must have the software configured to run that mode.
Stage III Coolingmist kit- 534.99 shipped
Coolingmist Deluxe kit- $279.99
upgrade to a 1 gallon tank with any kit ordered for only $20!
Add a float level indicator and led light for only $20 with any order!
Varicool controller only $222.99 shipped!
turboxs sale continues!!! as well as perrin. PM for pricing!
Slowboy racing-
Front mount intercooler with upper and lower piping- $1009 shipped
Front mount intercooler Lower pipe only- $759
Greddy intercoolers as well as hks also available
Other parts-
- APS FMIC Blow Off Valve shipped $259
-Magnus intake manifold For Evo 4-8 $699
-Helix Oil Catch Can $81.50 shipped
-HKS camshafts 264..272..combo..straight 272 deal, whichever- $xxx shipped
We are very competitive with our pricing
Savings on items paid for via Money order, Certified Bank check, and personal check (shipped after check clears) receives additional discounts
Regards,
Sales@importimageracing.com
Import Image Racing
sales@importimageracing.com
239 540 6385
Paypal= Whtezmbej@aol.com
Money order address=
Import Image Racing
431 sw 34th terrace
cape coral, fl 33914
Old Apr 12, 2009 | 09:18 AM
AF-Evo8's Avatar
-FMPFF44-105 Powerflex Mitsubishi Evo 5-9 Side Engine Mount Bushings (2 units required per car. how much shipped to 88101 for one of these i already have the cam side, and are these the purple ones?
thanks
Old Apr 17, 2009 | 12:03 PM
It Feels good to say...ITS FRIDAY!!!! Anyone catching the UFC fight saturday? We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 21 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
ALL GMS INLET HOSES BACKORDERED! Area 1320 wastegate brackets now in stock! Grimmspeed 04-07 sti/06-07 wrx ebcs back in stock!
VF 48's and VF 43's IN STOCK NOW! 52's backordered 1 month with a wait for a great price, just ask! or check out our site!
http://www.importimageracing.com/mm5...ategory_Code=5
only 2 greddy 3inch tic turboback 02-07 wrx SUPERSALE SUPER CHEAP catless turboback!!!!
Only 1 greddy SP2/invidia turboback under $700 shipped within 48 states!- http://www.importimageracing.com/mm5...tegory_Code=45
ITS TAX RETURN TIME...PM US OR CALL TO CREATE YOUR OWN CUSTOM COMBO SPECIAL!!!
INNOVATE DB-RED and blue WIDEBAND SPECIAL $219 shipped within 48 states, 15 in stock at this price!!!
BC RACING ER AVAILABLE NOW! Buy from import image to get free rear camber plates! BC racing available now!
GMS 38mm EWG KIT REVIEWS!- http://forums.nasioc.com/forums/show....php?t=1663732 WE HAVE WASTEGATE BRACKETS IN STOCK!
Need us to ship internationally for you? Whether it’s a car part or anything else let us help you get your parts through a name you trust! We are always looking for international importers to work with!
www.importimageracing.com ; 239 540 6385 visa.mc paypal to whtezmbej@aol.com AIM= Importimagerace Inquiries? Quotes? sales@importimageonline.com
Support? Support@importimageracing.com
Hours are 11am til 5pm monday through friday. then back at the other office 6pm on. We are generally here later, weekends are sales only, Please email/PM us and we’ll get back to you ASAP if we don't pick up as we are probably helping other customers or are away from our desk!
Old Apr 18, 2009 | 10:01 AM
ITS Saturday!!!! We will be in and out so please leave a voicemail and we will call back. We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 19 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 19, 2009 | 06:08 PM
ITS Sunday!!!! We will be in and out so please leave a voicemail and we will call back. We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 19 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 20, 2009 | 11:47 AM
ITS Monday!!!! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 18 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 21, 2009 | 10:56 AM
ITS Tuesday!!!! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 17 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
ALL GMS INLET HOSES BACKORDERED! Grimmspeed ebcs back in stock!
Old Apr 22, 2009 | 09:31 AM
ITS Weds!!!! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 15 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 23, 2009 | 11:01 AM
ITS Thursday!!!!We are open weekends! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 14 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 24, 2009 | 08:48 AM
ITS Friday!!!!We are open weekends! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 12 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Gates timing belts back in stock!
Old Apr 25, 2009 | 01:45 PM
ITS Saturday!!!!We are open weekends! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 12 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 26, 2009 | 01:48 PM
ITS Sunday!!!! I have the girlfriends family in town...so i will be available minimal hours today. I will return all pm's/emails/calls today at some point. We are open weekends! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 10 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 27, 2009 | 01:23 PM
ITS Monday!!!! We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 10 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 29, 2009 | 11:46 AM
ITS Weds!!!! Im shorthanded today. We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 9 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
Old Apr 30, 2009 | 01:53 PM
ITS Thursday!!!! We are available weekends. We have setup new hours found at the bottom! 3 Step Program- Quote- You send us your parts demands, We quote you the best deals, and We get your parts shipped as soon as humanly possible!! GMS radiator combos good to go! 9 GMS radiators in stock for 02-07 wrx/sti! mishimoto for 08+ wrx/sti! BEFORE YOU BUY ANYWHERE ELSE, CALL, PM, EMAIL, SMOKE SIGNAL US for our BEST prices, We want to EARN your business!!!! Grimmspeed stocking order in stock big savings! Trying something new! At work? Can’t use AIM or email because your boss is around!? TEXT OUR BUSINESS CELL PHONE (we do not answer calls on this #) for price quotes/questions- 201-675-8456!!! GIMMICK MOTORSPORTS HOOD DAMPERS, 38mm EWG kits, and STANDARD UP PIPES NOW IN STOCK!!!! MISHIMOTO RADIATORS IN STOCK!!!! For the BEST Bc Racing prices call us up if your ready to buy, we will not be beat! (may require valid quote from elsewhere) Mishimoto radiators available for most tuner vehicles, we are now a distributor and will not be beat! [i]Check out our site for great combo deals! click refresh on the homepage to see all the deals as there are too many to list at once! If we quote you a price, do not buy off site, call or paypal us. it will not be honored unless you do either. Pricing subject to change call or email for current prices
ALL GMS INLET HOSES BACKORDERED til may 4th! Grimmspeed ebcs for LGT and 08+ wrx/sti back in stock!
