TTP E85 conversion kits available! FullBlown Twin pumps, walbro's, Ethamax injectors!
Old Sep 2, 2009 | 06:24 AM
  #31
Levar's Avatar
Veteran: Army
I am planning to run E85 with my stock VIII turbo. I would like to only purchase injectors once regardless of the power levels I achieve. I am looking at the FIC 1250cc injectors both for my present as well as my future goals. Would they work fine with the stock VIII turbo? Thanks.
Old Sep 2, 2009 | 06:35 AM
  #32
warp9's Avatar
Great kit. IMO you should add the hobbs to your complete kit so people dont have to go out to get it. Also say youre driving and have to put 93 octane in it, do you need to switch maps?
Old Sep 2, 2009 | 07:25 AM
  #33
TTP Engineering's Avatar
You should not mix 93 and E85.
You should run a separate tune for both.
For in house installs we include the boost switch for free.
Old Sep 15, 2009 | 06:58 AM
  #34
450whp+ Ethanol conversion kits!
Originally Posted by TTP Engineering
Part #1- E85 TTP EthaMax Injectors
[TTP_e85_inj] $385
E85 Compatible TTP EthaMax Injectors
Brand new set of (4) TTP-Engineering E85 injectors. Each set is flow matched to within 1-2% 1 year comprehensive warranty flow reports included with your specific flow results drop-in fitment for easy installation Price listed is for a matched/balanced set of 4 injectors
PLEASE SELECT CORRECT SIZE FROM THE BELOW LIST:
STANDARD SIZING 1150cc
1250cc Compatible with Gasoline and Ethanol up to 100%
1350cc Compatible with Gasoline and Ethanol up to 100%
1450cc Compatible with Gasoline and Ethanol up to 100%
1550cc Compatible with Gasoline and Ethanol up to 100%
1650cc Compatible with Gasoline and Ethanol up to 100%
1750cc Compatible with Gasoline and Ethanol up to 100%
1850cc Compatible with Gasoline and Ethanol up to 100%
2250cc available upon special request!
All injectors feature the following...
100% new manufactured injector
Flow rates and set balancing completed pre-shipment
Flow balanced to within 1-2% (flow report included)
100% drop-in fitment (no connectors or adaptors required)
Excellent spray pattern and atomization for excellent idle and tuning
Coil latency available upon request
12-month comprehensive warranty
Best Pricing guaranteed! Click Here for PRICE QUOTE!
CLICK HERE to Instant Message us!
Click here to send us an EMAIL!
__________________________________
PART #2 - FullBlown Twin walbro high pressure fuel pump housing:
Full Blown Twin Walbro pump Kit for use with stock lines or AN fittings!
We have a dual pump hanger for the Mitsubishi Evolution that will allow you to drop 2 walbro fuel pumps into the stock gas tank. The days of drilling the stock gas tank and running loud external pumps are over. This is a must for those who are looking to make 500-1000hp. This kit comes complete with everything that you need to run a dual pump setup (besides the lines and hose ends). We have all the lines and fittings available as well.
We currently run this twin pump setup on our own 600whp stock block E85 car.
_______________________________________
Part #3- Additional Walbro fuel pump for boost activated 2nd pump
The Walbro high output in-tank electric fuel pumps are available in flow ratings of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour.
Walbro in-tank electric fuel pumps utilize a proven gerotor design. The outside dimensions, however, are compact enough to fit existing hanger assemblies, without modification. Coverage includes most popular Acura and Honda, Ford, Chrysler and many other Import applications.
Send us a message for PACKAGE PRICING!
Old Sep 17, 2009 | 02:45 PM
  #35
Veronica@TTP's Avatar
Great pricing! Call to set up an appointment for your conversion.
Old Sep 18, 2009 | 03:21 PM
  #36
Package price save you money!
PM for details!
Old Sep 22, 2009 | 03:01 PM
  #37
PM or Call for details
Old Sep 25, 2009 | 01:44 PM
  #38
PM with questions
[TTP_e85_inj] $385
Old Oct 5, 2009 | 03:22 PM
  #39
PM for details and pricing. Thanks!
Old Oct 9, 2009 | 04:20 PM
  #40
Best Price!
Amazing Results!
PM for details.
Old Oct 23, 2009 | 04:19 PM
  #41
PM for pricing and details.
Thanks!
Have a great weekend!
Old Oct 27, 2009 | 11:03 AM
  #42
Best pricing guaranteed!
Thanks!
Old Oct 27, 2009 | 08:45 PM
  #43
New 2400cc TTP HIAG injectors now available flowing up to 3000cc and up to 100psi fuel pressure!
[TTP_e85_inj] $385
Old Oct 28, 2009 | 11:23 AM
  #44
Join the ranks!
Thanks!
Old Oct 28, 2009 | 07:19 PM
  #45
willitas34's Avatar
Hi,
Just wondering why my post, and someone else were deleted? All we were doing was asking a question about your "ethamax" injectors....
I would like a response, are they or are they not FIC Blue Max Injectors?
will
