TTP E85 conversion kits available! FullBlown Twin pumps, walbro's, Ethamax injectors!
Old Aug 11, 2009 | 09:15 AM
Veronica@TTP's Avatar
Originally Posted by pure_evo
Is it safe for me to run the 1150cc injectors with a FP Red on E85? Also, can you PM me a price quote for all of the necessary components I'd need in order to run this? Thanks.
Depending on the boost level, you can run a single walbro up to a certain power level, then the twin pumps will be required.
Old Aug 13, 2009 | 08:49 AM
TTP Engineering's Avatar
Old Aug 18, 2009 | 12:17 PM
Join our growing number of customers running this set up.
We can do combination deals on the Ethanol conversion packages to save you some money!
Old Aug 18, 2009 | 12:58 PM
Paintballguy's Avatar
ahh its so tempting to go to an e85 setup. i hope they start pushing e85 to more gas stations.
Old Aug 18, 2009 | 01:07 PM
Here is the difference you can expect on the STOCK TURBO.
The lowest line is 93 octane, cams, TBE, O2 housing on 1050cc injectors.
The middle line is on E85 on the SAME BOOST AS PUMP 93 tune.
The HIGHEST line is at high boost 31psi on E85!
Old Aug 18, 2009 | 01:09 PM
Sometimes it's good to give in to temptation....this is definitely one of those times
It runs great in the car, that's for sure. Certainly makes the trip for us to fill up worth it but we too hope that more stations will start carrying it. Definitely would be more convenient for us and our E85 customers.
Old Aug 18, 2009 | 01:14 PM
Gordian79's Avatar
How compatible are these injectors with methanol?
Old Aug 18, 2009 | 01:24 PM
I just got a fpred. What kind of numbers are you getting with e85? Also, what size injectors are you running with e85 + fpred?
Old Aug 20, 2009 | 07:53 AM
+35whp on the STOCK turbo at the SAME boost level as 93 octane are the gains dynotested with E85 use!
Originally Posted by TTP Engineering
Part #1- E85 TTP EthaMax Injectors
[TTP_e85_inj] $385
E85 Compatible TTP EthaMax Injectors
Brand new set of (4) TTP-Engineering E85 injectors. Each set is flow matched to within 1-2% 1 year comprehensive warranty flow reports included with your specific flow results drop-in fitment for easy installation Price listed is for a matched/balanced set of 4 injectors
PLEASE SELECT CORRECT SIZE FROM THE BELOW LIST:
STANDARD SIZING 1150cc
1250cc Compatible with Gasoline and Ethanol up to 100%
1350cc Compatible with Gasoline and Ethanol up to 100%
1450cc Compatible with Gasoline and Ethanol up to 100%
1550cc Compatible with Gasoline and Ethanol up to 100%
1650cc Compatible with Gasoline and Ethanol up to 100%
1750cc Compatible with Gasoline and Ethanol up to 100%
1850cc Compatible with Gasoline and Ethanol up to 100%
2250cc available upon special request!
All injectors feature the following...
100% new manufactured injector
Flow rates and set balancing completed pre-shipment
Flow balanced to within 1-2% (flow report included)
100% drop-in fitment (no connectors or adaptors required)
Excellent spray pattern and atomization for excellent idle and tuning
Coil latency available upon request
12-month comprehensive warranty
Best Pricing guaranteed! Click Here for PRICE QUOTE!
CLICK HERE to Instant Message us!
Click here to send us an EMAIL!
__________________________________
PART #2 - FullBlown Twin walbro high pressure fuel pump housing:
Full Blown Twin Walbro pump Kit for use with stock lines or AN fittings!
We have a dual pump hanger for the Mitsubishi Evolution that will allow you to drop 2 walbro fuel pumps into the stock gas tank. The days of drilling the stock gas tank and running loud external pumps are over. This is a must for those who are looking to make 500-1000hp. This kit comes complete with everything that you need to run a dual pump setup (besides the lines and hose ends). We have all the lines and fittings available as well.
We currently run this twin pump setup on our own 600whp stock block E85 car.
_______________________________________
Part #3- Additional Walbro fuel pump for boost activated 2nd pump
The Walbro high output in-tank electric fuel pumps are available in flow ratings of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour.
Walbro in-tank electric fuel pumps utilize a proven gerotor design. The outside dimensions, however, are compact enough to fit existing hanger assemblies, without modification. Coverage includes most popular Acura and Honda, Ford, Chrysler and many other Import applications.
Send us a message for PACKAGE PRICING!
Old Aug 25, 2009 | 05:56 PM
Old Aug 25, 2009 | 06:05 PM
Our newest convert, ha ha how occult sounding, is loving his car on E85. Read his story here:
https://www.evolutionm.net/forums/ev...-hks-280s.html
PM us for pricing and with any additional inquiries.
Thanks!
Old Aug 25, 2009 | 06:09 PM
E VOL IX's Avatar
Very nice package Scott... LMK about 1650cc's, hanger, and one pump set-up for stock lines... thanks scott.. and dont forget you will be tuning it
PM me
Old Aug 25, 2009 | 06:16 PM
PM me
So you already have the single walbro correct? Adding the FullBlown Twin kit for use with stock lines and 1650cc. Got it...
Old Aug 25, 2009 | 06:18 PM
E VOL IX's Avatar
yea... just got the magnus intake on and im trying to sell my 35r so i can come down on a HTA88 or a BW turbo on the stock block/head and see what happens
the only E85 station ANYWHERE close to central NC is 3 blocks from my house and i live in redneck ville hahaha its a trip, one of those mini supermarket gas stations
Old Aug 31, 2009 | 02:00 PM
Get on board with E85!!!!
PM for conversion kit pricing.
