Precision 46mm Wastegates - Now in Stock!
Extreme PSI is proud to introduce the new 46mm Wastegates from Precision. These wastegates ARE compatible with Tial 44mm V-band flanges!
The PW46 is made from high grade, high temperature stainless steel and billet aluminum components. It features Precisions own purpose designed Kevlar reinforced wastegate diaphragm and a 347 stainless investment cast valve body. Precisions investment cast valve body has a smooth internal surface, giving you better flow and more accurate boost control. The PW46 was designed to be a direct replacement for other existing 44mm wastegate flanges, but will work best with the flange provided. The PW46 features a Nickel Chromium Alloy valve and 5 different 17-7 precipitation hardened springs. Also included are stainless steel inlet and outlet flanges with clamps. With a satin black anodized, 6061 aluminum billet wastegate cap you will have years of good looks and protection from the elements. The PW46 is generally compatible with most aftermarket manual and electronic boost controllers on the market today.
Five springs are included for a multitude of pressure combinations unlike the Tial where you are locked in to a specific boost pressure unless you purchase additional springs. Available only in black.
The PW46 wastegate is compatible with Tials WG44 wastegate weld flange, for a trouble free bolt on replacement.
We have MANY of these waste gates in stock and ready to ship! They are currently on sale for only $314.99!
That's 40 dollars less than our already incredible price on the 2mm smaller Tial V44 wastegate.
Please visit here to order.
Thanks,
Tony
ExtremePSI
Thanks,
Tony
ExtremePSI
