Perrin Intake users!! and others!
Hey guys,
For those of you running the Perrin intakes on their evo 8/9..
We decided to build our own UICP to work with this intake and the stock battery... We did not however want to run the IC pipe OVER the intake because of making it difficult to pressure test and sometimes putting pressure on the maf connector (as we've seen from some other kits).
Alot of our customer cars arent driven often and the small battery kits require battery tenders etc in cases where clients have alot of gauges, stereos etc... So we wanted to allow the use of the stock battery or upgraded stock size!!
So- we have a new 2.5" UICP in aluminum with stock bov flange, that goes under the perrin intake, and meets up with the stock FMIC outlet location! It includes a small adapter plate that moves the perrin heatshield/filter forward about an inch also! Completely bolt in!
The kit includes a new Stainless Steel battery tray that moves the stock battery slightly to the right for more clearance. Pricing will be very easy on the wallet and we are also machining a CBRD battery tie down for those of you that simply like our logo
For those of you with any other intakes, this should work with those also, if they keep the bov return close to the stock location!
Pics coming!
Cheers
CB
Pics coming!
Cheers
CB
LOL,
here is a thorough list of parts:
2.5" Alum UICP with stock bov coupler, black 4 ply hoses with tbolts for tbody and junction
Stainless steel brushed battery tray
Aluminum spacer plate to move the perrin intake towards the front of the car
Optional:
Pipe Seperate
Tray Seperate
CBRD billet battery tie down!
pics coming!
cb
Optional:
Pipe Seperate
Tray Seperate
pics coming!
cb
Does this spacer move the MAF forward? I would think it would have to. Reason I ask is I have the Perrin intake tube turbo to MAF and have the APS intake pre-MAF. And if I move the MAF then the intake will not line up. So I am assuming this set up will not work for me and I will have to stick with what I got.
have you seen any of our other welding work, looks similar, but i will post pics next week,
here are some of the other welds from our shop!
cb
