***AMS, CBRD, Mishimoto Radiators @ Mellon Tuning!***
AMS EVO 4-9 Small Radiator Kit
The AMS EVO 4-9 Small Radiator Kit was designed to free up space and weight under the hood. Our radiator kit will take up half the space of the factory radiator and saves nearly 10 lbs. Whether you need room for an enormous turbo or want to save weight, the super efficient radiator and high quality Fal 12” fan with shroud provide plenty of cooling even in bumper to bumper traffic.
This is the most complete small radiator kit available for your EVO IV-IX. Don’t be fooled by cheaper kits that use inferior parts and leave out necessary components. Our kit comes with everything you need for a painless installation and includes only the highest quality components.
The same radiator kit found on our record holding Drag and Time Attack EVO’s
Features:
•Takes up half the space and weighs 10 lbs. less than the factory radiator
•Efficient Aluminum radiator
•Shrouded fan for added cooling
Kit Includes:
•Small radiator designed to bolt into the factory mounting brackets
•Fal 12” fan with shroud
•Silicon Upper Radiator Hose
•Stainless steel hose clamps
•Kit uses factory lower radiator hose
•All necessary hardware
Specifications:
•12 inch diameter S blade puller 1.250 CFM Electric Fan
•53mm All-Aluminum Radiator
•12 inch long 1.25 inch diameter high grade silicone hose
•#20 stainless steel worm gear clamp
Applications:
•Mitsubishi Evolution 4, 5, 6, 7, 8, 9
•Fits USDM, JDM, and European Models
Please Note:
You will have to remove air conditioning components to use this kit.
Check it out here: http://www.mellontuning.com/index.ph...roducts_id=552
CBRD Thin Full-Size Radiator
The CBRD Evo 8/9 lightweight racing radiator utilizes the highest quality materials available to us. The goals for the radiator were as follows: More efficient cooling, clearance for big turbo kits, lightweight, and re-located outlet.
All of these goals were achieved providing an amazing product that is very popular with time attack participants, street cars, and drag racers. The radiator is supplied with a new multi-ply upper hose that reuses the stock clamps. The radiator has been revised to accept the stock radiator fan shroud for clients that would like a more efficient core while utilizing their stock fans.
With the CBRD radiator you will gain an extra 3/8" of clearance which will work perfectly for an upgraded turbo kit that requires extra room.
Total weight with fan: 9lbs.
We also offer the option of adding a slim line radiator for an additional $80. Please allow 5-7 days for the radiator to ship as these are built to order. Feel free to email or call us to check on status before you order!!
What you will receive in this kit:
1. CBRD radiator
2. New Radiator Hose
3. T bolt clamps
PLEASE NOTE: You will NOT be able to run your factory air snorkel unless you cut a hole in the underside for the newly relocated filler neck that this radiator offers.
Check it out here: http://www.mellontuning.com/index.ph...roducts_id=190
Mishimoto EVO 7-9 Performance Radiator
Mishimoto Mitsubishi EVO Performance Aluminum Radiator, 2001-2007
Having a turbo set up in your vehicle produces a great amount of heat. By replacing your current stock Evolution radiator with a top of the line Mishimoto performance radiator, you will undoubtedly notice a cooler more efficient running engine.
All Mishimoto Evolution performance aluminum radiators are designed and engineered to maximize cooling efficiency, boost engine functions, and most importantly protect your car from the overheating. With its lightweight dual core, 100% brazed aluminum, and polished tank ends, installation is effortless with a direct OEM fit, no cutting or modification is required .
All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap and a great warranty including accident protection.
Please contact us with any questions or to request a quote!
EvoDan2004
32
Mar 15, 2016 08:32 PM
STM Tuned
Dec 16, 2015 10:51 AM
STM Tuned
Aug 25, 2015 09:39 AM
Mellon Racing
Evo 'For Sale' Suspension / Brakes / Handling
Jun 27, 2011 07:02 AM
