Big Power Fuel Solutions: Injectors / AFPR / Double Pumpers / AN Fittings & MORE!
Get the best pricing and service exclusively from MAP!
Give us a call at 1-888-MAPerformance today to speak with one of our sales specialists for help with your specific needs or start shopping here to browse a selection of our products offerings
MAP 2000cc High Impedence Fuel Injectors w/ PnP Adapters (Mitsubishi Evo & DSM)
Item Number: MAP EVO-FI-2000
MAP 2000cc fuel injectors utilize the same modified Bosch fuel injector as many of the other guys, but at a more affordable price point. These bad boys include plug and play adapters so installation couldn't be easier, however, being that these are high impedance injectors you will need to remove your resistor pack which will entail some wiring unless you pick up the resistor pack delete plug available below! Please note these are not to be used with oxygenated fuels like Q16!
Optional FIC Resistor Pack Delete Plug
To avoid cutting and splicing your resistor box harness, simply remove the resistor box and plug in the FIC Resistor Box Delete Plug. Easy! For use when replacing OEM or aftermarket low impedance injectors with high impedance injectors. ($22.00 additional)
Our introductory price: $679.99
MAPerformance Walbro 400 InTank Fuel Pump (Evo 8/9)
- Designed for engines with more than 500hp
- Award-winning OE technology
- High-pressure, high-flow performance
- Outperforms all current market in-tank fuel pumps
Pump Gas Version (F90000262) Starting at $159 or our MAP Modified Pump is $274.98
E85 Version (F90000267) Starts at $220.00
Full Blown Double Pump Hangers (FBMDP-EVO89)
Starting as low as $394.99
MAPerformance proudly offer the most cost effective fueling solutions in the industry! Chance are if you don't see what you're after in this thread we can get it and we WILL NOT be beat on pricing!
MAP AFPR Install Kits With AEM Regulator Starting at $192.99
PM Me for Exclusive EvoM Member Pricing!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: NateAtMAP|||||: 1-888-MAPERFORMANCE x 114|||||: Nate@MAPerformance.com|||||Click to chat for an instant quote!
Finally, a fuel feed line solution for your EVO X!
This MAP fuel feed line kit replaces your entire factory feed line from the fuel pump housing to the fuel rail with 6an hose. Supplied push-on EFI fittings allow for an easy installation that requires no modification to your fuel pump housing or fuel rail!
Why replace your factory fuel feed line? Restrictions in the factory line cause pressure drop from the fuel pump to the rail; depending on the application a fuel pressure reading at the fuel rail might be 5, 10, or even 15psi lower than the fuel pressure at the pump. Take a gander at any fuel pump flow chart and you will find that fuel pumps flow significantly less at higher fuel pressures. To put this into perspective a Walbro 400lph fuel pump flows roughly 253lph at 90psi (13.5 volts) in comparison to 300lph when pressure is reduced to 75psi. An additional 50lph translates into almost 100whp of additional fuel capacity on E85!
This kit is available with or without a FueLab inline filter, however, please keep in mind that any aftermarket fuel pump (outside of the DW65C) will eliminate your factory in tank filter making this a pretty good idea.
Did you know that ALL MAP Fab in house manifolds are built with the following features?:
100 Percent polished schedule 10:
MAP invested hundreds of hours into developing a system to polish schedule 10 to our specification including research into the best possible tumbler, sampling a wide array of aggregate to generate the perfect finish to start with.
All manifolds welded on back purge stations
ALL MAP in house fabricated manifolds are tig welded and 100 percent back purged. This a process by which shielding gas is introduced to the interior of the welded area to prevent the molten metal from being exposed to oxygen. This results in stronger, more uniform and cleaner welds.
All MAP in house fabricated manifolds come with thick, laser cut/cnc'ed stainless flanges
Resulting in longer lasting and more aesthetically pleasing parts
All MAP in house fabricated manifolds come ported
Where some companies will simply grind away excess material for a simple transition into the runners, MAP manifolds are actually ported and shaped for maximum flow.
All MAP manifolds are backed by our Lifetime Ownership Guarantee!
When purchasing a MAP manifold, purchase with confidence. We guarantee that manifold for the lifetime of your ownership of it (valid for the original purchaser only).
MAP Complete T3 Turbo Kit (Mitsubishi Evo X)
The wait is finally over as you can now get the MAP treatment in a T3 configuration using some of the best components available! Choose from four killer PTE turbochargers (please don't hesitate to contact us for suggestions) and turn your horsepower dreams into a reality. This kit includes every component you will need to complete the installation.
Included Components
Turbocharger of your choice
3" Stainless Steel V-Band Downpipe with Flex
304SS Tubular Exhaust Manifold with CNC Transition Head Flange to 1.5" Primaries
Cam Angle Sensor Heat Shields (not pictured)
Turbosmart Comp Gate 40 Wastegate
Wastegate Dump Tube
Stainless Steel Upper Intercooler Pipe
Oil Feed and Return Lines
All Applicable Gaskets, Hardware, Clamps and Couplers
Included Components
Wastegate Dump Tube
