ToxicFab Products for EVO 8 & 9 @ Mellon Racing!!!
1 Post
These Products are only a small fraction of the vast inventory we have here...check us out here at: MellonRacing.com
ToxicFab Forward Facing V Band Manifold EVO 8/9
This is a Stock Frame Forward Facing Manifold for Evo 8 & 9s. Want to get the most power out of your stock or stock frame turbo?? This manifold will help you do that! This manifold helped Tyler Wolf reset the stock turbo World Record when he ran a 10.08 @ 132.93MPH! He will be going back to the track soon to get that 9 second slip!
**Build times are usually 4+ weeks but vary depending on product(s) order & how busy we are. Please contact us before placing your order, thank you!**
**Note - Please obey the laws when modifying your vehicle as some changes to OEM equipment may be punishable by your local or state law enforcement. Off Road Use Only.**
Check it out here:http://www.mellonracing.com/index.ph...oducts_id=2845
__________________________________________________ _______________
ToxicFab Foward Facing Manifold EVO 8/9
This is a T4 Twin Scroll Manifold for Evo 8 & 9s! Want to get the most power out of your T4 turbo? Place your order today!
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2843
ToxicFab Foward Facing V-Band Hot Parts Kit EVO 8/9
This is a full hot parts, including a lower intercooler pipe.
What's included
* VBand FF Manifold
* 321 Stainless 3" O2 Housing
* 321 Stainless Dump Tube
* Lower intercooler pipe with couplers and clamps
* Comes with a FREE semi polished cam sensor shield
This same kit was utilized on Joey "Junkbox"'s Evo which ran an 8.98 @ 167MPH in the 1/4 mile!
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2849
ToxicFab Ported Intake Manifold EVO 8/9
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2858
ToxicFab Race Catch Can EVO 8/9
Turbo cars, especially high horsepower cars, are known to have oil blow by. If a catch can is not used that blow by can get into your intake, turbo, FMIC, piping & intake manifold. Not only will that hurt performance but it can make a mess. ToxicFab's Race Catch Can is built to help relieve the most amount of crank case pressure as possible!
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2855
ToxicFab Stock Frame 02 Dump EVO 8/9
Evo 8 & 9 Stock Frame 02 Dump! This is bolt on product, made out of 100% Stainless Steel! Our 02 Dumps are usually slightly more expensive than others on the market because they are designed for maximum flow & are hand ported! They also have perfect engine bay clearance & do not rub or touch anything. Just like every other ToxicFab product it is covered by a Life Time Warranty!
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2848
Toxicfab Stock Frame Foward Facing Hot Parts Kit EVO 8/9
This is a complete Stock Frame Forward Racing hot parts kit for your Evo 8 or 9.
What's included
* Forward Facing Stock Frame Manifold
* 02 dump
* Lower intercooler pipe & J pipe with couplers and clamps
This same kit was utilized on Tyler Wolf's World Record Stock Turbo car which ran a 10.08 @ 132MPH in the 1/4 mile!
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2850
ToxicFab Stock Frame Foward Facing Manifold EVO 8/9
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2844
ToxicFab Stock Replacement Manifold EVO 10
This is an Evo X Stock Replacement Manifold! Ugly stock ported manifold isn't working for you anymore? Want to get the most power out of your stock or stock frame Evo X turbo & add a little "bling" to your engine bay? This manifold will help you do that!
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2847
ToxicFab Stock Replacement Manifold EVO 8/9
This is the product that helped Collin start ToxicFab! Stock Replacement Manifold for Evo 8 & 9s. This is definitely our best selling item as we have around 200 customers running this manifold world wide! Ugly cast stock manifold holding you back on power? Collin recently redesigned the manifold so it uses 1 less short radius bend & now uses a long angle radius 45. The new design equals better flow & more HP! Order yours today!
Check it out here: http://www.mellonracing.com/index.ph...oducts_id=2846
What's included
* VBand FF Manifold
What's included
* 02 dump
