UR Hardpipe kit
Old Mar 7, 2004 | 10:08 PM
  #31
new 2 turbos's Avatar
Originally posted by Shahul X
wow, to the 2 of you who added the intakes, were they stock airboxes before?
New 2, think the intake did much, so the UR pipe kit may have added about 10 of the 15?
was the dyno indoor temp or did the 2 dyno runs come at differant ambient temps?
-shahul
going off the "seat of the pants" dyno, i would say they had about hte same effect. it's hard to say since i did not dyno after only the intake, the car felt stronger though. then after the piping, the car felt a lot smoother all the way across the power band.
i believe the shop was about 67 degrees inside when these results were gathered.
i'm happy with the mods and don't regret spending the money. i would recommend these pipes to any one. i didn't go with the BR kit because of the cold starts here in CO, i want to stay with the full size battery, in it's stock location. although both kits look great!
Old Mar 8, 2004 | 07:54 AM
  #32
Shahul X's Avatar
i am looking at the Bushur IC, and they come with lower IC pipes, is that better or the lower pipes from the UR kit....im a bit confused I guess....
what IC are you all using with the UR piping kit?
-shahul
Old Mar 8, 2004 | 11:57 AM
  #33
Grifter_MP5's Avatar
I didn't go with the Bushur ic pipes because I have the AMS intercooler and they wouldn't work together. If you have the bushur intercooler I believe you will have to use the bushur pipeing. Someone correct me if I'm wrong.
Old Mar 8, 2004 | 09:45 PM
  #34
with the buschur fm, you have to use their lower piping due to the ic entrance being on the rear of the tank, not the side. their ic can be used with any upper pipe though, i'm pretty sure. since their upper pipe can be used with the stock ic.
shahul, i still have the stock ic. looking at the buschur one though. either that or cams and gears are next......
Old Mar 9, 2004 | 02:43 PM
  #35
Shahul X's Avatar
yea, i think i'll do the ams ic and the ur hard pipe kit
-shahul
Old Mar 9, 2004 | 03:14 PM
  #36
gldenchld's Avatar
When your ready to order give me a call.
-Zach
Old Mar 9, 2004 | 08:56 PM
  #37
MYEVOVIII's Avatar
Any numbers as far as performance over stock? Is pipe same diameter? Also how much shorter will it make over stock length?
I really like the look just wonder if it's worth purchasing. I am more about go then show.
Old Mar 9, 2004 | 09:18 PM
  #38
Shahul X's Avatar
-Zach
I will just doing wheels, springs, sway bars, and brakes right now.... gonna be a month or 2....
-shahul
Old Mar 9, 2004 | 09:33 PM
  #39
You didn't read this post did you. I already posted this.
Old Mar 10, 2004 | 05:00 PM
  #40
zstryder's Avatar
You say stock location, does this mean it will work with the stock airbox?
Old Mar 10, 2004 | 06:18 PM
  #41
MYEVOVIII's Avatar
Grifter MP5
I must have missed your post . Thanks for pointing it out to me.
zstryder it will work with the stock airbox location. I know it fits around the ARC box which is the same size.
Old Mar 15, 2004 | 08:56 AM
  #42
gldenchld's Avatar
Just a few left then a couple of weeks left
Old Mar 26, 2004 | 02:00 PM
  #43
gldenchld's Avatar
ttt
Old Apr 16, 2004 | 03:55 PM
  #44
gldenchld's Avatar
bump
OakosAutomotive
EvoX 'For Sale' External Engine / Power
41
Aug 16, 2013 12:47 PM
Vivid Racing
Nov 23, 2010 10:02 AM
vipevo9
Mar 17, 2010 11:31 PM
DrivelineSales
39
Sep 8, 2009 11:34 AM
Vivid Racing
May 2, 2008 11:48 AM
