The UTEC has landed.
In the world of Subaru WRX tuning, the TurboXS UTEC is a smash hit, and with good reason. It's simple, effective, easy to install, and easy to use.
Now it's available for your Evo.
If you haven't heard of the UTEC, it's a plug-and-play piggyback ECU device that allows you to alter fuel, timing, and boost settings for your Lancer Evo. It is programmed using a simple terminal program (like HyperTerminal, which is included with every Windows installation). Each one comes with a starting map, so you don't have to worry about programming it to get it to run right away. There are several choices for which map ships with the device, and later on we'll have various other maps available on our web site.
Installation is very easy; access the ECU, unplug the ECU harness, plug the UTEC into the ECU, and plug the ECU harness into the UTEC. Plug in a ground wire and you're done. Easily reversible, too, with no trace of installation.
TurboXS Evo UTEC - click me!
Click the link for more info, pricing, and to order. Now shipping, but initial production is limited!
--Dan
Mach V
MachEVO.com
Originally posted by JustDSM
What if any differences are there between the EVO/WRX UTEC revisions? Software and hardware..
--Dan
Mach V
MachEVO.com
Yes, through the TXS tuner...
- Wideband Air Fuel (9.0:1 - 25.0:1)
- Visual and Audible Knock Detection
- 4 Spare Inputs (such as RPM pickup, injector duty cycle, MAF, MAP, TPS, etc)
Originally posted by Shahul X
do you install, or can we get dyno tunes at Altered Atmosphere?
-shahul
-shahul
--Dan
Mach V
Dan, can you answer my previously posted question?
--Dan
Mach V
MachEVO.com
Originally posted by Karash
So to add wideband capability of any kind you must get their $700 product as well or will it work with any of the cheaper brand of wideband sensors?
--Dan
Mach V
MachEVO.com
