All Engine Management Needs Answered!!!
AEM Engine Management System $1689.99
AEM’s Plug & Play Engine Management System (EMS) will forever change the way you look at and perform fuel injection tuning! This user-programmable system plugs directly into a vehicle’s factory ECU harness and requires no additional wiring or hardware.* Windows™-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish “quick keys” to any pertinent information during the tuning process.The AEM EMS’s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
Installs in Minutes
Plug & Play Technology - No Wiring Necessary
Uses all the Factory Sensors
Fuel Table Automapping
Base Maps Included
Programmable Traction Control
Onboard 512kb Datalogger
10 Cyl Sequential Fuel Injection
16 General Purpose Outputs
7 Definable Switch Inputs
Electronic Boost Control
Soft Cut Rev Limiters
2 Step Launch Control
Wet or Dry Nitrous Control
Definable Knock Control
Full Idle Control
4 EGT Inputs w/Fuel Control
16/32 Hybrid High-Speed Processor
ApexI Power FC D-Detro $1429.99
The Power FC proudly stands as A'PEX's answer to the constraints and limitations associated with most piggy-back style fuel controllers. The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path. From multiple point fuel and ignition control to VTEC engagement (Honda applications) and boost settings, the Power FC is capable of accommodating even the most demanding performance enthusiasts.
Currently available only through Power Excel Shops, the Power FC replaces the factory ECU and controls all engine parameters.(Off road use only, no OBD-II) Installation is as easy as replacing the factory ECU. (Some minor rewiring is required on select vehicles.) The factory engine harness does not need to be replaced and all critical accessories such as air conditioning continue to function. By using the optional FC COMMANDER, the user can adjust and modify a wide range of settings. By changing various parameters and data, the Power FC will adapt to any of your performance needs. Since there is no need to upgrade ROM chips or trade in ECU's, the factory ECU can be kept by the original user.
The Power FC operates off of three Main Menus. These menus are : Monitor, Setting, and ETC.
In Monitor Mode, the Commander can display up to 10 parameters of data in real time. Monitor Mode can display:
Engine RPM
Ignition Timing
Vehicle Speed
Air Flow Voltage (Pressure Sensor Voltage)
Injector Duty Cycle
Boost
Knocking Level
Battery Voltage
Intake Air Temp
Water Temp
In addition, there are 4 display patterns allowing 1-8 parameters to be shown on screen at once. The data displays in numerical real time values with the option of a real time 10 second graph display. Peak Hold values and Display Hold functions only require the touch of a button. The Map Trace Mode allows Ghost Map Tracing of the Fuel Correction and Ignition Timing maps. This allows the user to visually see what point of the map is being used in real time. The Ghost Map Trace function leaves markers on the used portions of the map for easy reference.
Setting Mode allows full access to the 20x20 ignition timing and fuel correction maps. The user can adjust any portion of this map in 5x5 sections. Air flow correction values can be entered for vehicles upgrading air flow meters. Injector pulse correction menu is used whenupgrading injectors on the engine. The Acceleration Enrichment Correction function improves response under hard and sudden acceleration. The Cranking Fuel Injection menu corrects the amount of fuel when the engine is being cranked, or when the water temperature is cold. A separate Water Temp menu allows fuel correction according to water temperature. The RPM menu allows rev limiter settings and idle RPM levels. Access menus also vary according to specialty engines. Rotary engine Power FC's accommodate leading and trailing ignition maps. Honda engines Power FC's allow for VTEC control. Complete boost control is possible by using the optional Boost Control Kit (Not necessary for vehicles that come factory turbocharged.). Changing data is easy: just access the desired point on the map or data, and push the FC COMMANDER keys in the appropriate direction.
The ETC Menu contains utility parameters such as : version information, LCD screen Brightness, and Initialization of all Data. In addition, the ETC Mode allows the user to monitor all factory sensors through one screen. This screen can tell the user if any sensor is in use or malfunctioning.
The Power FC also comes preprogrammed with several base maps. (Currently with Japan Domestic Market Vehicle Maps. Minor initial tuning may be required. Please contact your authorized Power Excel shop for more information.) This makes the initial tuning process much quicker. As with all other fuel controllers, the POWER FC should be tuned on a dynomometer by a trained professional. A high grade air/ fuel ratio monitor is also recommended during tuning to ensure best results.
FC COMMANDER
The FC COMMANDER is a hand held controller designed to allow access to the vital parameters within the Power FC. The unit allows a wide range of data modification through its large back lit LCD display. The unit has been designed so that one finger can control a wide array of data. Once connected, the Apex logo will appear in the screen taking the user to the Main Menu. From here, the user can access the three Main Menus (Monitor, Setting, Etc.) The FC COMMANDER "communicates" with the Power FC control unit therebycreating one of the first interactive user friendly fuel management systems.
BOOST CONTROL KIT
The Boost Control Kit is an optional kit designed to control boost through the Power FC. Simple connection to the Power FC allows the user to access a full self-learning boost controller. The Power FC allows up to 4 different boost presets for any stage of driving. The high grade solenoid valve is the same one used in our Super AVC-R boost controller. As with the S-AVCR, the Boost control kit allows increased boost response and boost stability at high RPM's
TurboXS UTEC $1029.99
UTEC standard features include:
Plug-&-Play installation with OEM connectors for EVO VIII
No cutting, splicing or additional sensors required
20 minute, do-it-yourself installation
End-user programmable via PC or PDA with HyperTerminal and serial cable
Fine tune the maps for your exact setup
Pre-programmed base maps get you started quickly and safely
Base maps for our Staged upgrade packages, dyno proven and road tested.
Don’t waste hours tuning just to get your car to idle and cruise decently
Maps can be e-mailed or simply downloaded then uploaded
Four (5) maps plus “stock mode” selectable with a flick of the switch
Create custom maps for street gas, race gas, nitrous, or whatever
No need to lug around a laptop just to switch between your programs
Optional remote dash mounted switch availabl
Fuel, ignition timing, and boost are programmable in 250rpm increments up to 9000rpm over 10 load sites
Complete ignition timing control
No need to worry about the factory ECU pulling timing anymore
Be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map
Fuel control
Controlled via MAF sensor signal offset
Tune stock and larger than stock injectors
Load reference
MAP (manifold pressure)
Closed loop boost control programmable via Throttle Position and RPM
No more re-adjusting the boost controller due to changes in temperature or altitude
Keeps boost low while in closed loop fuel mode for reliability
Knock control
Automatically retards timing when the knock is detected safeguarding against engine damage
Adjustable knock threshold, timing correction, and duration
On board data logging
Provides valuable information to assist you in tuning
Built in programmable solenoid controller
Control nitrous, water injection, intercooler water spray or any other solenoid device
Drag racing launch control (secondary rev limit used during launch)
Shave precious time off your launch
Free software upgrades
As we add more features, simply download the latest software version from our website and upload it to the UTEC
Future features (available free via software upgrade) include:
Primary rev limit control
Maximize potential of larger turbochargers and valve train upgrades
MAP to MAF signal conversion
Eliminate the Mass Air Flow sensor and run any turbo you
Installs in Minutes
Base Maps Included
Full Idle Control
Engine RPM
Ignition Timing
Vehicle Speed
Injector Duty Cycle
Boost
Knocking Level
Battery Voltage
Intake Air Temp
Water Temp
FC COMMANDER
BOOST CONTROL KIT
Fuel control
Load reference
Knock control
InjectedPerformance
Evo 'For Sale' Electronics / Lighting / Audio
18
May 11, 2010 01:46 PM
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
evo-monstar
Lancer Engine Management / Tuning Forums
43
Jun 11, 2008 04:43 PM
GNV Motorsports
14
Nov 28, 2005 11:44 PM
Boost Solutions
Mar 22, 2004 10:48 PM
