Perrin Boost Tubes!!!!!
Old Apr 16, 2004 | 01:53 PM
Vivid Racing's Avatar
Arrow Perrin Boost Tubes!!!!!
Perrin is releasing the Evo Boost tube, and yes Vivid Racing gets first dibs! We will take orders for the first 30 boost tubes available. The PERRIN Performance™ EVO boost tube is a direct replacement for the upper boost tube spanning from the throttle body to the cold side of the turbocharger. Adds performance and horsepower by increasing air flow to the motor. The PERRIN Performance™ upper boost tube maintains a constant inside diameter and ultra smooth interior surface. The PERRIN™ upper boost tube will work with all factory replacement blow off valves.
Available in 3 bold colors RED-BLUE-BLACK
You do not need to purchase a smaller battery or a relocation kit to use the PERRIN™ boost tube.
$269.99 !!! FREE Shipping!!!!!!!!!
CLICK HERE for complete information about this product. Contact me for ordering information.
The first one to do install pics and a complete write up on this bad boy gets $20 off!
Old Apr 16, 2004 | 02:34 PM
TheGVR4kid's Avatar
you mean cold side of the IC?
Old Apr 16, 2004 | 02:43 PM
Old Apr 16, 2004 | 02:57 PM
hotrod2448's Avatar
Does that not expand alot uder boost? I would have to think mostly hard tubing with a couple of silicone unions would be better.
Old Apr 17, 2004 | 11:02 AM
babyburner's Avatar
i don't see how this is a good product. The larger the piping the larger your turbo needs to be to push allll that air. This is why the drag turbo cars still have somewhat small piping. That is just HUGE
Old Apr 17, 2004 | 07:15 PM
ex-honda's Avatar
Why so much for one hose. You can get a set of Sampco intercooler hoses for $239? And that includes everything, from the turbo to the throttle body.
Old May 14, 2004 | 07:17 AM
nothere's Avatar
I'm having a bit of a problem understanding the length of this hose.
Does it reach from the intercooler to the throttle body? If that were the case it would be about 4 feet long.
Or does it reach from the first bit of pipe from the intercooler to the throttle body?
thanks
Old May 14, 2004 | 08:01 AM
chapter8's Avatar
ahhh questions....questions
Vivid?
Old May 14, 2004 | 08:42 AM
Deceit's Avatar
It looks like it goes from the t-body coupler to the last coupler before the cold side of the IC outlet.
Old May 14, 2004 | 09:21 AM
chapter8's Avatar
ahh, sounds good....but useful info like how many bends and if the distance was shortned would help....since these are factors that could affect turbo spool up and power.
I like how they are not made of metal and are not as suseptable to heat soak like the factory ones or upgraded (auliminum and steel) pipes
Old May 14, 2004 | 09:40 AM
it is about 2 feet maybe a little more in length. I just pulled one out and looked at it. it comes with that long hose, and two hoses which are about 6-8" angled hoses. It looks like it goes from the throttle body and connects to some stock hosing on the cold side of the IC. i looked at our evo to see what it would hook up to, but its kind of pointless seeing as how we dont even have the same set up on there anymore. I will check it out when another evo comes in.
Old May 14, 2004 | 09:52 AM
nothere's Avatar
ok, that answers it. you still use the bit of pipe that is right after the intercooler
thanks
Old May 15, 2004 | 09:04 PM
co_evo's Avatar
Question?
I am a bit confused. It states that you need to buy a smaller battery to use this product, but in the picture of it installed in the yellow EVO the battery in that car looks stock. Is the battery in fact a smaller battery in the picture? Thank you.
James
Old May 16, 2004 | 06:57 AM
evo_dadi's Avatar
nah it doesnt need for you to buy a small battery kit.
Old May 18, 2004 | 05:07 AM
EVOeight's Avatar
Will it fit with the factory airbox in place or do you have to have an aftermarket intake?
