EVO MR Diverter Valve
Old Jun 29, 2004 | 10:17 AM
  #91
zstryder's Avatar
Why not just stick with the GReddy? Drivability IMO is improved with that unit.
Old Jun 29, 2004 | 10:20 AM
  #92
tama_mog's Avatar
not really for me, and I've adjusted the thing to heck....can't seem to dial it in perfectly without fluttering.
Old Jun 29, 2004 | 10:29 AM
  #93
SirAragorn's Avatar
yeah this ones oem also. can't get much better fit and finish than that! I'm getting mine just to get rid of the plastic piece that comes with the usdm evo. I have no plans to turn up the boost.
Old Jun 29, 2004 | 10:37 AM
  #94
tama_mog's Avatar
I'd be sold if this thing holds 23-25 pounds.
Old Jun 29, 2004 | 10:53 AM
  #95
mitsuorder's Avatar
I spoke to Cal and I believe he said that his sources told him it would hold 23lbs no prob, maybe you could do a pressure test for us Cal?
Old Jun 29, 2004 | 05:47 PM
  #96
Gruppe-S's Avatar
I have MR DV unit on my EVO but I can not run up to 23psi due to ****ty CA 91oct gas. My current boost setting w/ Blitz sbc-iD is at 20.7psi about 4500rpm to redline. I am also using S-AFC w/ custom tuned settings.
I am pretty certain this unit will hold up to 25+psi after confirming w/ our sales-rep in Japan
Thanks
Cal
Gruppe-S
Old Jun 29, 2004 | 06:21 PM
  #97
tama_mog's Avatar
Hi Cal;
So after talking to your rep in Japan? They've tested the thing and said it'll do 25+? This is important to me since I'll be running a big turbo and need to know if this bov is up to the task....I already have a greddy type-s and am thinkin of switching. I think the most boost I'll see is probably 24-25 pounds realistically so if this thing can take it, expect a phone call tomorrow. =)
Old Jun 29, 2004 | 07:05 PM
  #98
EvoJimbo's Avatar
this is the best BOV for the EVO. Low boost performs like stock while holding strong at high boost. I can now hold 21-22 psi when it usually tapers with the stocker. This is defiinetely better than any aftermarket ones.
Old Jun 29, 2004 | 07:12 PM
  #99
ARVSHOP's Avatar
diverter valve..
hey cal....save me one and let me know oonce you get them..for sure ill buy it....also the turbo outlet..or you can call me!
THANKS!
Old Jun 29, 2004 | 07:16 PM
  #100
EVOag's Avatar
Registered User
when is the next shipment...i will definitely order one....
Old Jun 29, 2004 | 07:50 PM
  #101
Grod101's Avatar
hell ya this BOV is da bomb....... my evo runs so much smother now...
Old Jun 29, 2004 | 09:56 PM
  #102
tama_mog's Avatar
.....when you guys say it's the best....are you comparing it to other valves or just saying it performs well.....the best thing is an actual pressurizing test from someone or gruppe-s.....it's not that hard to do guys and it'll help out potential buyers like me a lot. I don't want to spend another hundred or so dollars on a valve that won't hold as much boost as my current valve, the greddy type-s. If you guys could, help me out and do a little experiment. =)
Old Jun 29, 2004 | 10:26 PM
  #103
zstryder's Avatar
Have you tried the one spring mod? That should solve any problems you have with the TypeS.
Old Jun 29, 2004 | 10:29 PM
  #104
tama_mog's Avatar
yeah, ready silver surfer's thread to death, did the one spring mod, that stopped the stalling. But the thing flutters like hell....no matter how loose I have the adjustment screw.....And it is way too loud with my intake, I feel like my car whistles to the cops. That's why if this thing can hold boost (24-25psi) and drives like b4 when I had a stock bov, I would love it to hell.
Old Jun 29, 2004 | 10:32 PM
  #105
zstryder's Avatar
Hm, dunno what the problem could be then. It shouldn't be whistling if you have it pretty loose. That's a major bummer!
