Extreme Agency Power
Old Aug 9, 2004 | 12:14 PM
Vivid Racing's Avatar
Agency Power In Stock
This fuel rail is a direct replacement for the factory unit. The CNC machined piece is anodized in Agency Power Gold. It fits with the stock fuel pressure regulator and fittings and can be set up to work with aftermarket units as well. The fuel rail also has a location to put an aftermarket fuel pressure gauge with no modification.
Why is this Agency Power Fuel Rail better then stock? Well, the AP fuel rail has a wider diameter for fuel flow then stock. As well, the AP rail is designed to fit larger injectors such as Blitz, RC, and other common brands. When upgrading to a larger turbo set up or needing to upgrade your fuel system, the AP rail will accommodate your needs. While keeping stock fitment and performance when additional fuel is not needed, the fuel rail is also a great dress up piece.
$120 FREE SHIPPING
This pulley is a direct bolt on using the factory belt NO MODS NEEDED. The AP pulley weights about 1.1lb compared to the stock pulley weighing in at 4lbsand is .5 lbs lighter than perrin's. The weight savings in rotational mass equates to an awesome serious performance increase. If you're worried about the stories you have read on “crankwalk” or unbalancing the motor, then don't fear. The factory harmonic balancer reduces engine noise and vibration in the cabin and deleting this will NOT destroy your motor. The pulley is completely safe as a bolt on giving you between 3-6 horsepower and increased throttle response. Tested and used on the VividRacing.com 500HP EVO VIII!
Made from billet CNC machined Aluminum.
View from the VividRacing's Evo
$109.99
Free Shipping
questions? send pm or give me a call at 480.966.3040 ext 226.
jacky
Vivid Racing
11
Jul 15, 2008 08:48 PM
Vivid Racing
225
Jul 3, 2008 11:43 AM
Vivid Racing
Evo 'For Sale' Suspension / Brakes / Handling
Nov 15, 2005 10:48 AM
Vivid Racing
10
Jul 12, 2004 12:29 PM
