Two-piece Stock Replacement Rotors are here!
#31
Can you PM me a price for a front set both 2 piece and 1 piece shipped to 41048? Thanks.
EDIT - How available are replacement rings? Can you send me pricing for the rings and mounting hardware as well?
#32
Replacement rings:
http://www.racingbrake.com/Stock_Size_s/2441.htm
Mounting Hardware:
http://www.racingbrake.com/product_p/fk1-10.htm
#34
Originally Posted by Jasil
What's the difference between these and Performacne Friction? They look the same except for the dimples.
RacingBrake:
Bolt to “self-locking” sleeve nut without having to use lock-tite providing positive fastening without the rattling noise.
Performance Friction:
Curved Vanes.
RacingBrake:
Convergent curved vane.
RacingBrake:
- More efficient air ventilation – Center mount provides air inlets from both inboard and outboard.
- Heat load on rotor hat is balanced from both sides of friction surfaces.
- Heat transfer from disc surface to rotor hat is greatly reduced due to longer distance to travel.
- Stress load is balanced due to the mounting surface is at the disc center.
- Disc is uni-directional, hat can mount to disc on either side without having to identify left or right yet its truly directional, avoid mix-up in installation, very innovative
#37
Originally Posted by scorke
Your located in NJ, where abouts> also price for fronts shipped to 07059/picked up from your location, and rears, if you could give me a price on fronts only and both that would be great!
Scorke
Scorke
81 Futon St.
Boonton, NJ 07005
I sent you a PM with the information.
Just to confirm the cost to replace the front rotors would be two rings, for 323 dollars or so plus 40 dollars for two hardware kits, which comes out to 360 or so?
Scorke
Scorke
#40
Originally Posted by Derek888
how long before your 2 piece rear brakes will be available?
We shall put them back soon.
#42
Originally Posted by sdoow
We have a minor issue on the hardware (interfering with dust shield if not removed) which is being corrected just to be safe for all installation.
#43
please PM a price shipped to NJ 08755
i have no clue where boonton is in NJ
im looking for a price on fronts and fronts and rear packages
with ferodo pads for my Mitsubishi 06 Evo 9 MR
...are those ok for daily use
and how bad is dusting
i ran ds3000s on my honda and it ruined a good set of Spoon wheels but they are black anyways but its permanently coated in a rusted metal dust
#45
Originally Posted by ecuflasher
What happened to the 2pc front rotor with curved open slot? Don't see it listed on your website anymore.
http://www.racingbrake.com/EVO_8_RB_...p/2065-381.htm
