Fortune Auto 57mm custom built coilovers $999
Contact Import Image to Order Your Set Today! (Click Me)
We are excited to announce our newly released V2.0 500 series coilovers for the Evo.
**Want coilovers that are super comfy for daily driving?
**Want coilovers that are setup for mixed use? Street & occasional track day/ autoX
**Want coilovers that are setup for an all out Track Monster or AutoX?
We can do it!! We custom valve and spring coilovers to your SPECIFIC NEEDS!
AT NO ADDITIONAL COST!
PM ME to help us dial in your ultimate setup!
We are proud to say very few manufacturers offer this much support and insight. Especially coilovers at this price point!
For those of you that are not familiar with our products here are a few key points.
- USA Technical Support
- Custom Valving and Rates available
- Expert Suspension Setup and Advise
- Coilover Rebuilds in the USA
- All Coilovers are Dynoed at the Factory
Fortune Auto utilizes the largest piston in its class*. 50mm Piston (57mm Piston Housing)
Installed on some Evo's
We also have successfully campaigned our time attack/ tt car last year with great results. This has given us great insight on suspension setup: taking multiple factors into consideration such as tire selection, sway bar size, intended usage of car etc.
Here are some pictures and videos of our coilovers in action.
and some videos
Version 2.0 UPDATES. Included in every new set of Fortune Auto coilovers.
1.First off we have upgraded the rubber bushings to resin gaskets. This will help isolate noise but the new resin gaskets will last much longer!
2. All v2.0 coilovers will also incorporate an upgraded synthetic shock oil that has better friction and heat control. Furthermore cavitation is greatly reduced limiting shock fade and inconsistent dampening. This basically gives you a better and more consistent performing shock over a wide range of temperatures and conditions
$999.00
TITAN 2-Way Dampers©Custom built to your specifications.
A true solution for your racing requirements!!!
Incorporates all the great features of our 500 & 510 series coilovers.
Furthermore it includes these key features.
- Remote reservoirs for increased fluid capacity and cooler operation in race conditions
- Separate compression and rebound control
- Rebuildable in the USA!
- Japanese made forged piston rod
- Japanese made nitrogen gas chamber
- Every set of Coilovers gets dyno'ed , matched, and tested to the highest standards
- Every set includes a printed sweep Dynograph thru the click range providing graphical and numerical proof!
- Custom built to your specifications
- Remote reservoirs
- Double adjustable / 32 way compression - 16 way rebound
- Stainless steel body / piston
- Pillowball mounts
- Forged aluminum locking collars
- Dust boots on all pistons
- 50mm piston
- Anodized aluminum camber plates
- Fully anodized body
- 3 year Manufacturer's Warranty
- Height adjustable
- Pre-load adjustable
- ISO 9002 certification
Contact Import Image for pricing on TITAN Coilovers (Click Me)
These are the same coilovers (500 series) that just won last weeks time attack!!
You don't need $4000+ coilovers to be competitive. Podium 1st Place Finish at Time Attack!
Just to clarify we do not sell these direct.
I keep getting PM's for pricing.
We are just on here for technical support and setup.
Please PM Import Image for pricing (Info in my sig)
All other questions please pm me
Just an FYI
Here is the thread where coilovers can be purchased
https://www.evolutionm.net/forums/ev...ort-image.html
