Put Your Power to the Ground - AST / Cusco / Fortune Auto / HKS / KW / Whiteline
Tons of good coilover options available for the Evo 8 and 9. Give us a PM and we can help pick out the right coilover for you, along with offering very competitive pricing. Check our website out for all options, and PM us for the special EvoM Forums price.
KW Coilovers
KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up.
KW Variant 3 Coilovers
Fortune Auto
These are a great option for the budget minded racer. They are rebuild-able right here in the USA and all options offer custom spring rates, helper springs(extra charge) and valving(free).
Click the images to learn more:
500 Series
510 Series
DREADNOUGHT© Inverted Coilovers
500 Series
510 Series
HKS Coilovers
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS’ all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard – but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Hipermax III Sport
Hipermax III Sport
KSport Coilovers
Version RR Damper System
Ksport Version RR Damper System is built specifically for road racing only. Aggressive rates and valving are chosen for maximum handling and performance with acute reaction and responsiveness. Integrated with 36 levels of dampening adjustment, simultaneous compression and rebound adjustment, lightweight aluminum mounts, and pillow ball upper mounts on some applications.
Kontrol Pro Kit
Key Features
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Click the image to learn more:
Kontrol Pro Evo8/9 PM FOR SALE PRICE
Key Features
Stance Coilovers
Stance SS+ [SS-D] The Special Setting Dampers were developed to meet the special demands of the circuit. The SS-D is valved to work in conjunction with race tires to maximize traction. The SS+ [SS-D] were used to win national titles in both drifting and time attack; setting the highest benchmark for itself – winning.
Stance SS+ [SS-D] (SS & SS+ also available)
Moton
AST
This is old news for most, but for those who have not heard of Whiteline, the brand graces a number performance suspension components that work hard to deliver real results and performance outcomes for vehicles and motorists the world over.
Whiteline’s primary focus was initially delivering ‘bang for your buck’ handling gains from the simplicity of an anti sway bar. But over the years, the expertise, the knowledge, the reputation and the products have grown since progressed to include additional offerings such as the range of infamous anti lift/caster kits, roll centre adjuster kits, adjustable control arms, camber kits, strut and chassis bracing.
Adjustable Front 26mm or Rear 22mm or 24mm Sway Bar
Replacement Bushings
