Cusco Trunk Bar back in stock!
Hey guys,
Just got another shipment of Cusco Trunk bar for your EVOs! Please hurry while supply lasts! Price is $75 Shipped.
Thanks
Cal
gruppe-s
510-498-8400
Thanks
Cal
gruppe-s
510-498-8400
Originally posted by batty
is that necessary if u already have a rear strut brace
Thanks
Cal
Gruppe-S
Cal, can you post pictures of yours installed? I went to do the install on mine last night and I'm a little confused as to what I need to remove to install it. I know I have to lift up the carpet I'm not sure on where the bolts go. Do I have to get under the car???
Thanks alot,
Ron
Thanks alot,
Ron
Thanks alot,
Ron
Thanks alot,
Ron
When you lift up the trunk carpet, you will see two round black sticker looking things on both side of trunk (near the back of the trunk). its very hard to see, but if you push the back panel back a little, you will see them.
Peel those black stickers off and you will see the holes that were already pre-drilled from the factory. Then you should be able to mount the trunk bar on there.
hope this helps..
Cal
gruppe-s
Originally posted by evo 8 ya
What's involved with the instillation?
Originally posted by AWDTurbo4
anything positive or negative if you use both? this one and the rear strut brace?
negative side of this will be... can't put larger luggages? hahaha
