New Dash Gauges
Old Oct 21, 2004 | 05:06 PM
  #46
Mikebuzzsaw's Avatar
Did it include instructions?
Old Oct 21, 2004 | 08:22 PM
  #47
mattfl's Avatar
they did, they weren't the greatest instructions in the world but they did the job. If you can install a boost gauge you can put these in.
Old Oct 22, 2004 | 08:07 AM
  #48
GrimDog's Avatar
is this a complete console replacement? (Cant check ebay at work) It doesn't affect odometer reading at all either correct?
Old Oct 22, 2004 | 09:57 AM
  #49
mattfl's Avatar
no it's not a complete replacement. The white gauges are just covers, you slide them overtop of the exsisting gauges
Old Oct 23, 2004 | 02:52 PM
  #50
evilevovegas's Avatar
Heres mine installed. I also have white gauges with blue needles.
Attached Thumbnails New Dash Gauges-gauge-1.jpg   New Dash Gauges-gauge-2.jpg   New Dash Gauges-gauge-3.jpg   New Dash Gauges-gauge-4.jpg
Old Oct 23, 2004 | 06:12 PM
  #51
freedom's Avatar
The ebay auction states that they install w/o removing the needles. How does this work?
Old Oct 23, 2004 | 06:41 PM
  #52
you just slide them under the needles. Put the needle through the hole then slide them into place. Hardest part is routing the wires.
Old Oct 23, 2004 | 06:50 PM
  #53
Evokid04's Avatar
I like them. I don't really care for the light blue color in the middle though.
Old Oct 24, 2004 | 01:42 PM
  #54
freedom's Avatar
So the center hole is large enough to pass over the center of the needle?
Old Oct 24, 2004 | 02:37 PM
  #55
yes
Old Oct 24, 2004 | 02:41 PM
  #56
moviebumm's Avatar
9 out of 10 terrorist work with Bush
Old Jan 10, 2005 | 05:26 PM
  #57
Ookami's Avatar
Originally Posted by Mevolution2002
yeah, all you have to do is get a exacto knife and cut little slits on the back where the power is flowing to the inner circle. I dont have pics of it, but i sure do like it a lot better without them. I just wish the RPMS didnt read up to 10000, thats my only problem with these gauges and the annoying buzzing from the light dim switch they give you.
Just put my order in for this kit and I was wondering ... can you see the needles clearly with the inner circle gone? The gauges look great besides the light blue inner circles ...
Old Jan 11, 2005 | 10:03 AM
  #58
avengerhed's Avatar
the needles are lit separately by the stock bulbs, the center piece does nothing to help or hurt your ability to see them
Old Jan 11, 2005 | 10:22 AM
  #59
Mevolution2002's Avatar
Avengerhed hit it right on the nose. I will suggest some thin double sided tape cause i had some problems with the needles sticking cause the over lays werent completely held down. Besides that its pretty much cake.
Old Jan 11, 2005 | 01:56 PM
  #60
avengerhed's Avatar
did you actually cut out the inner circle?? or just cut the trace to it the keep it from lighting up?
