good amp for subs?
Hey dude,
Did some research on your woofer (1241D) and I see that the MAX RMS is 300 watts. That means you're gonna want to get an amp that is at least 800 watts RMS (so you don't work the amp when you're thumpin'). There's so many different ways you can go. Being a Phoenix Gold owner, I'd recommend them, but since you have Alpine, I'd go with Alpine. I used to have Alpine on my woofers 3 years ago and I loved the Alpine amp. The MRD-M500 looks sufficient for those woofers. The woofer's you chose are for SQ (sound quality), so if you want to stick with that theme, the MRD-M500 would be perfect. The MRD-M1001 is unneeded unless you decide to purchase woofers that can handle a lot more power, but then that means you're going to be tapping into the SPL (sound pressure level) industry rather than the SQ (sound quality) industry. IMO, the MRD-M500 would be perfect. Either way, make sure the amp you get can handle at least 800 watts RMS so, like I said above, you don't over work the amp when you're bumpin'. You're gonna have some nice bass no matter which way you decide to go.
Originally Posted by importstylz07
i was thinkin a 1200 x 2 or something..
Originally Posted by dizzigital
you should always bridge both woofers into 1 mono channel for maximum output and synchronization.
getting a mono amp that is not high current and running both these subs, either you are going to have to run it at 4 ohm and reduce the power output of the amp (but at a higher SQ), or you are going to burn the amp out running them at 1 ohm and it will sound like *** IMO.
JL makes some of the best amps around Zapco also is VERY high quality I would go with one of these I went with JL but thats cause Zapco is really hard to find and kinda spendy. Not that JL is cheap but you get what you pay for.
Originally Posted by KevinD
you can't bridge anything on a mono amp. there is nothing to bridge. a mono amp is already running one channel. if you meant to say run the subs in parallel, again this is not a true statement. if he has two DVC subs, (which i believe they are) then he is going to need a 2 channel amp or a high current mono amp. because there are few high current amps and are usually a little more money, the best bet is with the 2 channel (although i think one HC amp was already mentioned, might want to look into that one). if you get the 2CH then you can either run the coils in parallel for eahc sub (2 ohm load each) and each sub on its only channel, or you can run the coils in parallel and run the subs in series (4ohm load) and then bridge it across the 2 channel amp.
I have a question for some of you audio guru's. I have an Audiobahn 4002t amp hooked up to 1 (12") MA audio competion subwoofer. The sub is dual 4ohm voice coil and amp is a 2 channel that I'm running bridged. With this setup, is it better to run it 8ohm or 2ohm and what's the difference? Currently I have it setup on the sub:Positive connected to negative. Then positive goes to amp and Negative goes to amp. This is an 8ohm connection. It's pounds really hard but will it be better to run 2ohm?
what would be a good amp to use with two apline type R's (1241D)
I was thinkin about runnin 600watts to each sub...Any suggestions??
thats what a good buddy of mine that has worked in car audio for years just said would work great.
EvoIX2240
Sep 17, 2009 05:35 PM
roo@bpauto
14
Feb 14, 2006 05:23 PM
Kaane
For Sale - Cars For Sale
Jun 1, 2005 02:58 PM
