Black Rims
Old Jan 5, 2005 | 05:53 PM
sleet's Avatar
^^ I agree, but my car is black. Perhaps i'll buy some of those little stickers and see how they look.
Old Jan 6, 2005 | 03:33 PM
Chris@nolimitmotors's Avatar
i like it all black
Old Jan 6, 2005 | 03:40 PM
Ev0 1's Avatar
How would I and what do I need to get my rims looking like that? (The glossy one)
Old Jan 6, 2005 | 03:45 PM
tokeone's Avatar
i currently cant get any better pics cause the weather has been bad and the cars filthy. plus, you cant really see the black on black from much of a distance (hence why its a closer up pic)
its just three coats of flat black paint (same used on the rims) no sanding or anything. just taped up the car and had at it. no issues and its at least 3 months old.
Old Jan 7, 2005 | 07:27 AM
cleanevo's Avatar
PPG has a single stage paint Called CLV this stuff is bullet proff . this paint is good for everything simple such as mtr to tranny to wheels , All it it is is paint and hardener and a splash of redeucer 2:1:.5 .Prep the wheels bye water sanding them with 400 wet/dry 3m sandpaper and a red scuff pad, Get all the shiny of the wheel , wash the wheel and mask your tire off and Seal them with a PPG DP primer made too as a sealer , then shoot the Clv 3 coats , and then you are done . sounds hard but if that is the finish you want you will not get with a spray can , you can powder coat but then you have too take your wheel off . I have been painting for 10 years now and this is a very easy and strong way too do it .
Old Jan 7, 2005 | 08:23 AM
lacartus's Avatar
Does this paint have to be applied with a compressor and spray-gun? Thanks for the details, that's the best description (citing specific paints) that I've seen.
Old Jan 7, 2005 | 08:43 AM
DaGuL's Avatar
What about the powder coating process? I've got an extra set of rims (as per signature) that I'd probably experiment with if they don't sell...
Old Jan 7, 2005 | 08:52 AM
Ev0 1's Avatar
Where can I get it from?
Old Jan 7, 2005 | 09:15 AM
sleet's Avatar
There is a local shop here that paints the wheels like that, I might do powder-coat tho just because they might last longer but i'm not too sure yet.
ETS Michael
ExtremeTurboSystems.com – WA
43
Apr 1, 2009 08:13 PM
EvolutionVI
Oct 23, 2008 09:12 PM
kidneythief13
13
Jul 21, 2008 01:14 PM
Wicked05
May 26, 2005 08:03 PM
