removing scratches
Old Feb 6, 2005 | 04:27 PM
obsidian's Avatar
removing scratches
Tried to search but didn't show anything.
I recently debadged my black evo. When I was removing the sticky, my friend let suggested I use his clay. Apparently there was some crap on it because I now have some minor scratches where the bagdes used to be.
The area also looks duller. I tried to give it a couple of coats of wax but still looks dull.
Any hints?
Old Feb 6, 2005 | 04:35 PM
evo77's Avatar
Got this from www.meguiarsonline.com.
How to use ScratchX by hand to remove defects like these,
1. Scratches
2. Swirls
3. Bird Dropping Etchings
4. Water spots
5. Scuff and Mars
++ = Success!
A couple of important notes to consider,
1) Clear coats are harder than traditional paints. This means they are more difficult to remove defects out of, especially by hand. This is part explains the increase in popularity of the Porter Cable Dual Action Polisher.
2) ScratchX is NOT a wipe-on, wipe-off product, (WOWO), it's more of a wipe on, work in product, (WOWI). You need to apply with a clean foam applicator pad and work the product in with a little passion.
Here is how to remove a bird dropping etching or an isolated scratch.
1. Only work a small area at a time - about 6 inch by 6 inch area or smaller
2. You can apply using a combination of circular motions and straight-line motions
3. Work the product against the finish until it looks as you have almost run out of product.
4. Re-apply the product and repeat the above steps 2-3 more times
When I apply ScratchX like I have listed above, I am able to get out about 95% of a bird dropping etching or isolated random scratches.
The trick is to work the product in until it just begins to disappear and to apply more than one application. You see, the ScratchX, like all Meguiar's Paint Cleaners, contain a diminishing abrasive, as you work ScratchX in, the microscopic diminishing abrasives gently abrade the surface removing small particles of paint. But as you work it in, these diminishing abrasives breakdown. Thus, they quit abrading the finish and actually polish the finish to a clear, high gloss. This diminishing action turned polishing action is a benefit to you because it enable you to work out defects without leaving scratches behind.
Because the diminishing abrasive breakdown, you need to re-apply and repeat the process until the defects are removed.
Note: You can rarely remove a bird dropping etching, or a scratch, from a clear-coated finish with one application.
"A little technique goes a long way"
ScratchX works, if you work it. It takes a little practice to get the hang of removing defects out of modern clear coats with hi-tech products like ScratchX. It' not like the old days with a traditional lacquer or enamel paint job where you could apply some old-fashioned rubbing compound and in a few passes, the scratch would be gone, (and so would a lot of your paint).
High gloss clear coats are thin delicate surface coatings that are easily dulled and easily scratched. Once they are dulled down and/or scratched, it takes the right product, the right technique together with the human element of care and passion to massage them back to a glistening gemstone.
Have patience, and if at first you don't succeed, try try again.
Mike Phillips
Technical Specialist
1-800-854-8073 ext. 189
mphillips@meguiars.com
Old Feb 6, 2005 | 05:32 PM
obsidian's Avatar
Thanks e77
Old Feb 6, 2005 | 05:50 PM
SurfguruJon311's Avatar
Anyone know if they sell that stuff at like autozone or someplace like that or do you have to buy it online?
Old Feb 6, 2005 | 06:32 PM
mump's Avatar
autozone, pepboys, walmart....they all carry it.
s84kam
Jun 24, 2009 05:34 PM
Fas4dr
12
Feb 20, 2005 09:43 PM
magz
Jul 3, 2003 03:42 PM
imapunkclaimer
May 13, 2003 08:20 PM
