Removing ghost lettering?
Old Mar 31, 2005 | 01:09 PM
gonzstarr's Avatar
if u use wd-40 ur gonna need rubbing compound afterwards. ur best bet is 3M adhesive and tar remover(clear coat safe). i've used it several times, on paint, windows, and even my ***...
Old Jan 21, 2011 | 11:04 AM
`coke_c2's Avatar
I debadged my 03 VIII over the summer finally starting to fade but if I look real close I can still see really faded text, looks like mitsu threw on the badge then clear coated maybe?
Old Jan 21, 2011 | 11:17 AM
Ghost1t's Avatar
Originally Posted by krafty
I have already used the goo-gone and removed all the goo. I debadged quite a while ago, and have washed and waxed it several times, but when I shine a light up to it you can still see the outline of the lettering where the badge was.
Maybe The Paint Behind the Badge when it was on did not wear off by the sun and now the mark is there
Thats my take
Old Jan 21, 2011 | 11:23 AM
drocksmash's Avatar
I had a similar issue.... the lettering was gone after goo off and some light scrapping, but the diamond symbol was always ghosted.
get some of the meguiers (spelling) scratch off.
I was a friends house and he slapped some on, instally gone and I have yet to see it back (15+ car washes since) I saw some at Lowes and oriellys/schucks
Old Jan 21, 2011 | 12:07 PM
YogSaahoth's Avatar
Veteran: Army
rubbing compound or even scratch/swirl remover would probably work best because it will actually remove microscopic layers of clear coat...this will "accelerate" the natural erosion that created the difference in appearance in the first place. Not sure if it will actually work, but it theoretically makes sense. Oh and u will need some sort of power tool to achieve maximum effect of the rubbing compound...needs to be brought up to heat. I use a simple power drill with a foam pad bit, but a proper buffer will be safer and produce a better finish
Edit: on second thought you can probably use the scratch remover by hand...but those compounds work best when the area becomes slightly heated by friction...so rub fast lol
Old Jan 21, 2011 | 01:07 PM
F0RSAKEN's Avatar
Yeah, I used Meguirs Scratch-X on drock's car, worked great.
dtkb87
For Sale - Part Outs
147
Jul 19, 2014 10:13 AM
Ghost1t
May 27, 2010 06:47 AM
LetsGo82nd
Mar 1, 2009 11:58 PM
Ghost22
Aug 10, 2004 08:53 PM
